Vacuum Chucking
Vacuum Chucking
Vacuum Chucking
Jeff Morneault in northern Maine
>Hi folks, I just bought a used vacuum pump and would like to get into vacuum chucking. I was over at joewoodworker.com taking a look at how they set things up and noticed they sell a kit through veneersupplies.com
http://www.veneersupplies.com/product_info.php?products_id=2300
Has anyone been using this setup, the price seems right, what do you think. Any suggestions would be appreciated because I'm just getting started on this. Thanks
My other option was to go with a setup explained by Steve Schlumpf on sawmillcreek.org
http://www.sawmillcreek.org/showthread.php?t=84279
Re: Vacuum Chucking
Rob Wallace
Re: Vacuum Chucking *LINK*
Rob Wallace
>Jeff:
A few more links to read about vacuum, chucking - see below.....
I would not trade my vacuum chucking system - immense convenience and time savings.... with excellent results. I'm setting up a second system on a "finishing" lathe I'm building.... just scored my second vacuum pump on eBay.....
Rob Wallace
Vacuum Chucking Links
Re: Vacuum Chucking
George Balock
Re: Vacuum Chucking
George Balock
>Jeff,
I couldn't live without my Vacuum Chucking system. All of the things that are difficult to do without it become simple. I made parts of mine from stuff that you can get at the hardware stor. I bought a gauge and valve from McMaster Carr and the rotary adapter from Craft Supplies (I got the E-Z Vacuum Adapter). Not wanting to make chucks, I bit the bullet and got the Oneway Drums. I have the small and medium ones.
Some woods will work better than others (bubinga was particularly pourus) I have used masking tape to partially seal the wood some or to cover small insect holes to get more vacuum leakage. Goo dluck with this I'm sure you won't be sorry.
George
Re: Vacuum Chucking
Dick Hines
Re: Vacuum Chucking
Dick Hines
>There a write up in Woodturning Design fall 2005. Has pictures and some good info.
Re: Vacuum Chucking
Re: Vacuum Chucking
Steve in NC
>I used the set up in Woodturning Design for the plumbing but purchsed the alum. Oneway chucks. I also purchased an adaptor that goes through the headstock from Craft Supply. Bot work great with my PM
I tried making my own chucks but by the time I got the wood and dedicated faceplates and then dealt with leakage, it was easier to go with the Oneway chucks. (They work great)
I also would not trade it. There is a bit of a learning curve, (take small bites) but once mastered it is a real treat to use.
Steve
Re: Vacuum Chucking
Re: Vacuum Chucking
david
>Jeff:
IMHO, a kit of parts is useless without a good instruction manual, detailed procedures, and good photos. My suggestion is to copy the vacuum setup from another turner--one that he/she has proven that works well. The plumbing of the setup can vary so much and if you are very adept at mechanical systems I can see it happening for you, but why re-invent the wheel? Once set up, though, you will find it invaluable...
Re: Vacuum Chucking
Re: Vacuum Chucking
>Hi all, Thanks for the responses. I'm definately not looking to reinvent the wheel on this and was hoping I'd get a positive response from someone who may be using the setup bought through veneer supplies. It's going on a pm 3520b using a gast 1/3hp 3heb vacuum pump. I wish I had that article in Woodturning Design Dick. To order a back issue through them is about two to four weeks shipping through usps :'(
Re: Vacuum Chucking
Neighbah...
Jorge Castaneda~Downeast Maine
>Hello Jeff,
I'll take pictures of my set up tonight or tomorrow and post them. It works great and I think of it as a very wise investment.
Take care
Jorge
Enjoying the fog in Stonington, ME
Re: Vacuum Chucking
Re: Neighbah...
>Hi Jorge, I'd definately like to see how your vacuum's setup. Looking forward to seeing your pics. And anyone elses who'd like to post!!
Re: Vacuum Chucking
Vac set up
>Jeff,
In the first picture you can see my vacuum pump, a 6cf Robin Air, I am showing it by itself, the lathe is at the moment covered by tons of stuff, the stuff in background upper left is not part of it.
On the top of the pump you can see a fitting and the vacuum line, follow the line and you come to a gas filter, a little further you see all the fittings involved including a valve and manometer, following the line you see a silver cone and a rod with another silver fitting on the end, this unit is an �easy vac� from Packard, this goes through the head and spindle of the lathe, to the right a vacuum chuck from OneWay
I don�t remember the price per item, but the whole was around $300.
In the second picture you see the working set up.
Hope this helps
Jorge
Re: Vacuum Chucking
Re: Vac set up II
>Here is the working vacuum system.
Re: Vacuum Chucking
Re: Vac set up
>Hi Jorge, Thanks for posting those shots. Looks like the EZ adapter would be a good way to go. Seems to make things a bit simpler.
Jeff
