What's the hardest thing for you to do?
Steven Antonucci
steve antonucci
>Everyone here that turns knows that there is one thing (or maybe more) that they "just cannot do". For a long while for me, it was cut from left to right with a skew, but I seem to have conquered that now.
My current challenge is cutting multiple, consecutive beads all the same shape and size. I can roll a bead with a spindle gouge or a skew, cutting cleanly and efficiently. I mark all of the beads diameters carefully. I cut.
Some are fat, some are thin. Even though I carefully mark out widths, carefully cut downhill, I have yet to figure out the magic required to make a series of beads all look the same size.
So what's your biggest challenge?
Steven
Re: What's the hardest thing for you to do?
Don at Central Illinois
>The SKEW!! I still haven't come close to mastering (or minoring)it, yet.
robo hippy
>As far as going left and right with your tools, if you think about it, your hands just hold the tool, your body does all the moving. But, I do juggle, and use both hands for many things.
Steve, I know what you mean about multiple beads. Like my Kung Fu teacher said, "10,000 more times!" "but Teacher, that is what you said last time!". He smiled and walked away.
For me, it is visualizing hollow forms. I have done mostly bowls, and am branching into vessels/vases/hollow forms. A lot of them look pretty primative. Some look great. I will have to do a bunch more before the idea in my head comes out in the wood the way I want it to. Oh, well, I will have some I will sell cheaper because I don't like them.
robo hippy
mpax356
>Sanding. I always seem to miss some tearout or tool marks with the coarser grit and discover my sanding flaws when I have used the finest grit (when I am lucky) or after the finish is on when I am not lucky.
I am pretty comfortable with the skew after watching the Alan Lacer DVDs and doing the homemork on the 16 spindle blanks from a 2X4. Altho, I have to admit it is little like Sigfried and Roy's tamed tigers. It is still a wild thing that will bite you if you aren't careful!
Harry in beautiful, downtown Kulpsville
>For me it is that last finishing cut inside a bowl. David Ellsworth does it so well as does Mike Mahoney. I cannot seem to make it from the rim to the bottom in one, smooth, bevel rubbing pass.
Tidying the shop
Steven Kubien
>I suppose shear scraping a dried bowl, once it has been re-mounted on its tenon. Obviously, when a bowl-blank dries, it warps. I then mount it between centres using a wide friction pad/jamb chuck on the inside, clean up the tenon and then work the outside to round and fairly smooth while still between centres. When i flip around and put it back in my chuck, a little further rounding work is often needed and I cannot shear scrape it as smooth as I did when it was between centres. It could be a directional thing because I am now working from the headstock to the tailstock (opposite when working between centres). Odd thing is, somedays I start sanding with 180 grit (last night) and other times it is 80 grit (this morning).
Steve Kubien
P.S. And I wasn't kidding about tidying up.
Steven Antonucci
Canadian, 2112... Rush fan?
steve antonucci
Peter Charles Fagg (UK)
>Ditto! I have attended courses, read books, had fellow turners show me how they do it, but every time I try it, it digs, catches, doesn't cut or cuts too much!
Peter.
Thread chasing
Ken Grunke from SW WI
>I just could not get the hang of thread chasing, even with good advisors standing over my shoulder. Pretty frustrating, as I consider myself a fairly well coordinated guy with good hand dexterity but this time, it simply didn't help.
About your first re-mounting...
david
>After a piece has dried, I never found it necessary to re-mount other than on the tenon side. Turning the piece around would be to remove the tenon or make the foot. Am I doing something wrong here?
Sean Troy
>For me it's walking away from a finished turning and being satisfied. I haven't experienced that feeling yet.
After seeing them...
Steven Kubien
>...8 times in concert, including a drive to Detroit, ya, I guess I am a fan!
Steve
Re: About your first re-mounting...
Steven Kubien
>David,
The first re-mount allows me to round a tenon which has gone oval as the rough-out drys. Some species barely require this as they don't warp much during drying (red elm comes to mind). Right now I am working on some silver maple that warped badly.
I suppose I could just go straight to the chuck even with the warped tenons but the grip wouldn't be as good. I figure, why risk orbiting a bowl for the sake of a couple of minutes of work?
I take it you don't have this issue?
Steve
Donna Banfield
>Finding the time to read the postings on these turning forums, and having even less time to actually post a response! ;^)
Sort of seriously, I don't know how some of you guys do it. Take for example, John Lucas (who I know right now is at the AAW Symposium)...he posts or responds almost every day! On several forums! And he has a fulltime job!
And Steve Antonucci, you've got a fulltime job AND kids, and from the sound of it, you're a great Dad, too! The only thing I can figure out is that John Lucas only sleeps on Tuesdays and Thursdays between 2 and 4 am, and Steve, you only sleep every third Monday night! ;^)
Steven Antonucci
Only 8?
steve antonucci
>I think I'm around 15. Almost everything back to Permanent Waves except the last tour (Snakes and Arrows). Kids and such get in the way...
Some tours twice...
Steven
Remember Sean...
Steven Kubien
>...there's a difference between being happy and being satisfied. Happy is a good thing and allows for betterment next time. Satisfied means never advancing (if that's what you want to do).
Steve Kubien
Steven Antonucci
I don't reround the tenons.
steve antonucci
>Never had one issue with it.
couple of hundred bowls, I'm guessing...
Steve
Steven Antonucci
WoodCentral is my watercooler
steve antonucci
>I work from home, and I need a break from the usual drone, so I usually have a WC window open. I also try to keep 4 kids happy (try is the key word), and turn a couple of days a week.
All of this, and I leave for a hiking trip to Yosemite tomorrow, so I'll be scarce until July 4th. Planning on walking about 50 miles through the wilderness with my oldest boy. The things we have to do for our kids :-)
Steven
Finials among other things!
Ron McKinley
david
>I don't do too many twice-turned pieces, I guess. I have encountered oval tenons, but can't say that I've had to re-turn them round. Good to know, though...
Re: Remember Sean...
Sean Troy
>I'm always happy turning !!
Finding time to turn
>Put hay in the barn yesterday. Worked on electric fencing today. Tomorrow, finish cutting a short road through the woods. Next week, robbing the bees. processing honey. Every day, a few hours gardening or mowing.
ya but...
Steven Kubien
>I'm only 37 and I wasn't allowed to go to concerts until the Power Windows tour. As for Snakes and Arrows...I saw it I gotta say I was disappointed. The only older stuff they played also gets played daily on the local classic rock station. The boys were in top form as always but I came away wanting...something.
eaglesc
>reading the who made it threads
Jorge Castaneda~Downeast Maine
>Harry,
It was the same for me for a while, specially in deep bowls, it got easier when I changed from my do everything 5/8" gouge to a 1/2" one, and now I am graduating to the 3/8", Doug Thompson's 3/8" U is my "inside gouge" now, try that.
Jorge
Wondering where Kulpsville is...
