Re: Looking for cheaper replacement chuck key
Fog Tanner
>My preference is to loose unimportant things like eye glasses and sleep. Loosing a chuck key is simply uncivilzed.
You might try one of the machine shop supply places like Wholesale Tool or MSC. If you have one locally you could take your chuck in and see if they have anything.
Like John, I cured the problem by going to Vic, which uses a key that you can pick up at Wholesale, MSC, Home Despot, etc. I did this after going the route of a chuck body only Stronghold. Now I have a key for each machine.
I worked in a machine shop out of high school and going to college. I ran an engine lathe which had a "tray" built into the top of the headstock. You learned to pick up the key and replace it with your left hand. It became an automatic operation and I never left a key in the chuck and started the machine. I have seen that happen and a 2hp lathe can throw the key across the room - one reason you see lathes angled when one is behind another. Once you get in the habit, it is difficult to loose your chuck key, or start the lathe with it in the chuck. You will know when something doesn't seem right before you tirn the switch or go walking around with the chuck key in your hand to the bandsaw.
I have a dust collector hood sililar to the pictures in Raffan's books. I used some PVC pipe and fittings to make a rack which is mounted to the hood. A Oneway chuck key will fit in a pice of 1" PVC. I actually have a 1" T mounted on its side which has a short horizantal piece with holes drilled it it for my Vic T handle keys and tommy bars. This T is connted to another T, which has a short piece for my allen wrenches used on the chucks.
For the jaw screws I loose in the shavings, I now have a large magnet. Has aved a couple of hours digging through a pile of shavings at 2 in morning when I just had to finish something.
