Bowl: Ocean creatures did it!
david
>Opinions, please. This piece is 10-1/2" dia. X 6-3/4" ht. Wall thickness: 1/2". Looks like Douglas Fir-part of a log found after floating in the ocean for quite a while. Photo taken on my kitchen table with regular light from above. Lots of sea shells and sand in the holes, but mostly gone now. This has not been sanded at all--what you see are marks from my bowl gouge, ground sharp, but no attempt to achieve a smooth surface. Soaked for several days in Watco, but fairly dry now. Sort of thought the rough look went with the holes. Question--how would you finish this piece? Should I sand the inside and/or outside smooth, or leave it just as it is?
Re: Bowl: Ocean creatures did it!
Re: I'd sand the inside only...
>and leave the outside rough. It would give you a good contrast in the surface textures.
Ditto... Inside and lip only
Brian Hahn in SW Wisconsin
Bill Blasic
Bill Blasic
>David,
I would sand with 50 grit just to get rid of the tool marks as they seem to fight the grain as there is a lot going on with the holes. Regardless it will be a nice piece.
Bob Macgregor
>Nice soup bowl for serious dieters.
Steven Antonucci
Only two choices:
steve antonucci
>Either sand the whole thing to a high finish and the contrast will come from the bug holes or leave it alone.
I turn ash like this and spend more time picking out beetle frass and worms than I do on the lathe. Personally, I think the more "rustic" look suits this type of wood, but I also hate sanding.
Good looking bowl either way.
Steven
Sand the inside, burn (and texture?) the lip
Craig Daymon
Allen Neighbors
>I'd sand it inside and out with 220/280 grits and then finish it with whatever. It will smooth a little of the high spots, and look really worn. Well done, no matter what you do to it. :)
Mike Rubes, Apex, NC
>Hi David,
I really like this bowl, thanks for the pic.
Insofar as sanding, my opinion is that I would want it sanded, but not to the point of losing the ridges created by the tool. I like that detail in the wood quite a lot and an agressive sanding to make the bowl smooth would destroy that. I would say that as long as there isn't any bad tearout in the endgrain, then I would leave it as is on.
If somone really felt the urge to sand smooth, that could be done on the inside, but I wouldn't on the outside.
Just my opinion :)
Let us know what you decide to do, either way I think the bowl is a real winner!
Thanks for the pic,
Mike
PT means no shop time and a sore knee in Apex, NC
charlie belden
>My vote - sand off the fuzz and leave it at that. Extra smooth
and shiny just doesn't go with the wood
Texian
>David,
That's a wonderful piece! Agree with a couple others to leave the ridges, tool marks, and just carefully sand off the fuzz with some fine paper.
Thanks all!
david
>Re-chucking this piece will be a real hassle. The plan after seeing what your comments are: Will hand sand to hit the fuzzies and leave the tool marks, inside and out.
It will hold marbles or cookies
Wayne Carson "TX"
