>Hi All, I have some wood that I bought that is waxed and green. The shavings coming off the piece seem pretty dry. If I turn to finish in one session I get some warping over time. But if I rough turn and let it dry, how do I know when it's dry enough and stable? Is there some test you can do without buying an expensive moisture meter? Thanks!
>with accurate weighing device, or at whatever regular interval you decide. Record your findings. When piece stops losing weight over a couple of weigh cycles, then your piece is probably dry.
>David nailed it. The U.S.Postal Service has a couple of digital electronic scales for sale at fairly modest prices. A "moisture meter" measures the electrical resistivity at or near the surface of the wood, but gives no indication of the moisture content beyond about 3/4" or 1" deep. The wood can be dry on the surface and sopping wet inside. Measuring the weight is a better way.
Isn't that dependent on the relatively humidity (and temperature)?
I have several times used the weighing method. I write the weights on the piece if the wood isn't too dark. BTW, to speed up the drying the microwave oven technique works well, weighing after each short zap and cooling between zaps.
>Of course, it is related to relative humidity and temperature. Those are the two factors that determine what percentage moisture in the wood will be at equilibriunm with the atmosphere around it. Changes in relative humidity and temperature are why wood expands and contracts with the changing seasons.
The cheek works better than the lips because it is more sensitive to temperature for most people.
The reason this works is evaporative cooling. When there is moisture evaporation on the surface of the wood, the surface is cooler than the surrounding air. When the wood reaches a moisture content that is at equilibrium with the air around it, there is no longer any evaporation, and the wood surface will be at the same temperature as the air around it.
It just happens that our cheek, followed by our lips, are the two parts of the body that are the most sensitive to temperature. The difference is easier to detect when the wood and atmosphere are both ar a room temperature of about 70F.
>Thanks all, I like the ideas. I'll try the "cheek/lips" method and see if it works for me. I hope I left enough wood (1/2") to round it again. The bowls haven't been warping too much as the wood is pretty dry.
