Turning Monkey Pod
Turning Monkey Pod
Turning Monkey Pod
Ed Larson
>My stepdaughter just brought me two green debarked Monkey Pod logs from Hawaii. They are approx. 10 in dia and 15 inches long. About half the diameter is heart wood. I have sealed the ends. Need some quidance on how to handle them? Turn green and let warp?? Turn to wall to 10% let dry and return?? I'm looking at getting 4 bowls unless I turn and end grain bowl. Any suggestions appricated.
Re: Turning Monkey Pod
tek-Brunswick, Ohio
>I have only turned one piece of Monkey Pod. That blank was already dry when I got it. That was a couple of years ago. I remember having a little tearout in the usual places. It is a very pretty wood. It reminds me a lot of the stone tigers eye. You are lucky to have such a good step daughter. Maybe someone who has turned more of it will be able to comment. I sure wish I had some more. It made one of my favorite bowls.
Tom
david
>Other than being a bit open-grained, it is a good wood to turn. This wood is not high up on he desirability scale for Hawaii turners because of the proliferation of cheap monkepod salad bowls and calabashes from the Orient. Like $3.50 for a salad bowl. OK, that was a while ago. Perhaps now it is $9.50. We basicallly try to stay away from salad bowl shapes, and if I put out a piece for sale, I call it Rain Tree. This piece was turned end grain.
Mike Rubes, Apex, NC
>Hi David,
Very nice shape. Not only the shape, but the grain orientation really works well. I really like that shape.
Thanks for the pic.
Mike
So many things to try in Apex, NC
Allen Neighbors
>That bowl is absolutely beautiful, Tom.
Allen Neighbors
>Never turned it, but if it were my wood, I'd turn one wet and thin, and let it warp. Then I'd rough turn the next, and soak it. Then I'd try to save one chunk by sealing it and putting it in my referkiln for a year or so.
You'll probably get some better ideas from others, but that's just what I'd do. :)
Re: Turning Monkey Pod I will start
Ed Larson
>tomorrow. Allen, my thoughts had also been turn one wet so I plan to to that tomorrow. I will rough turn the other half and let it dry and see what happens. I dry mine in a paper bag with shaving and have had good luck with that. Will keep you posted.
Thanks for the responses. Ed
