Which screws to attach a blank to a faceplate?
wilbur
>I'm finally tired of my borg special #8 x 1 1/4" screws losing their head as I try to attach a blank to a faceplate. So I looked through the McFeeley's catalog to look for something more suitable or durable. Then I went crosseyed with all the choices available.
So I thought I'd ask here, since WC people know everything. What kind of screws do you use to attach a blank to a faceplate? My blanks are all less than 12" in diameter, and the thickest one is 5" deep.
And, yes, I am drilling a pilot hole that should be big enough.
Re: Which screws to attach a blank to a faceplate?
>I don't use a faceplate all that often, but I like the TapCon screws designed to drive into concrete. They are available at the Borgs and are blue. They have a Phillips drive (No 3?). I bought my faceplate blank and drilled the holes myself. The holes match the shaft diameter on the tapcon screws. The screws are somewhat expensive but really last.
Norm Smith
>Wilbur, I buy round head sheet metal screws # 8 & 10 by the box in different lengths( 1" to 2.5"), using the length that serves the purpose. I dont predrill wet wood. When the head of the screw starts to wear, I throw it in the garbage.
Norm
I like Spax screws
keith zimmerman, Normal IL
#8 and #10 square drive
Brian Hahn in SW Wisconsin
>I prefer square drive screws. They last a very, very long time. I use a screw length that is appropriate for the piece of wood, anywhere from 3/4" to 2".
The concrete screws that Barry mentioned are really good as well.
#10 and #12 Pan head Square Drive....
Wally Dickerman in Arizona
>Pan head screws are harder and have deeper threads because they're self tapping. Square drive is much better than Phillips or slotted head.
If you're using screws on endgrain wood you'll need long screws for good holding. For side grain wood, the length of the screw depends on the size and weight of the blank and how firm the wood is.
Wally
Second That
Jorge Castaneda~Downeast Maine
Roger
>Go to www.fredwilliamson.com then click on making a bowl. The screws he uses are sheet metal screws, and he mounts huge blanks on 4" face plates.It works.Check out the rest of the site while you're there, it's interesting. Roger
Bolts...not screws
Peter Teubel
>When I used faceplates, I used 1/4" lag bolts of various lengths.
Re: Bolts...not screws
Sean Troy
>I agree. 1/4" Lags are the way to go. I've been doing it that way for years and never had a failure including a 200 + lb. chunk of wood.
Screws in Punky Wood...
>Here is a method that I use in wood that won't hold acrews or a tenon for a chuck.
For each screw I bore a 1/2 in. hole in the wood and insert a dowel. The scew goes into the hardwood dowel and holds very well. A good way to save a pretty but bad piece of wood.
Wally
Great idea!
Ron McKinley
robo hippy
>The only time I use a face plate anymore is when I do natural edge bowls. I use a 3 1/4 inch forstner bit to make a flat spot, and mount the face plate. Otherwise, I will drill a recess the size closest to my chuck jaws, and expand into the recess. This works for me on bowls up to about 18 inch diameter. With the face plate, I use 8 by 1 1/4 galvenized deck screws. Usually only good for 2 or 3 uses before the heads are stripped. Never liked the square drive as the driver always seemed to get stuck. Probably not the proper size. Using the recess, the chuck never has to come off the lathe.
robo hippy
robo hippy
>Oh yes, if the heads are coming off the screws, then set the torque down on your drill. I am amazed at how many people set the torque at max, I only set it up to enough to drive the screw, which on my old Dewalt is between 3 and 4.
robo hippy
Richard Allen
Richard Allen
>Hi Wilbur
I find that Phillips head screws tend to have 2 to 3 uses before that head starts wearing out.
Square drive screws tend to have 2 to 3 uses.
Withe either philips or square drive you need to press into the screw. This isn't a problem when putting the screw in but can be an issue when removing the screw.
Capcon screws screws can use a hex socket to drive the screws. The point on these screws don't open up a hole in wood so a pilot hole is needed. There is no holding power in the point of the screw which means that the capcon screw needs to be a little longer for the same holding power as a fully threaded screw.
Lag bolts have a large hex head which is terrific for driving. Most lag bolts are made of soft steel and the head can be spun off if you don't drill a pilot hole.
I find the key for faceplate work is to prepare a flat or slightly concave surface for the faceplate to seat against. Pilot holes, especialy in dry wood. Short screws for most applications.
Wilford Bickel
>Another vote for Spax screws - I get mine from Highland Hardware. Never had a failure (knock on wood) since I started using them. They are strong and made to cut their way into the wood. Also, the advice from Robo Hippy is dead on - my 18 volt Dewalt is on 3-4 when I am attaching face plates. I also use every hole in the face plate - if it is there it gets a screw! I don't like flying wood!!
Steven Antonucci
And it works great!
steve antonucci
>I did this after the last time Wally posted this idea and it works better than advertised! I didn't even glue the dowels in, but just knocked them in with a mallet.
Steven
SPAX in #10 & #12 1 to 1 1/2"
Cyril Griesbach
Steven Antonucci
Almost any screw.
steve antonucci
>I use drywall screws when I'm in a pinch.
I also use coated deck screws with the philips/square drive because they are square drive and coating drives easier.
I am also fond of Durock/cement board screws. Sharp, a little thicker, and nice aggressive thread.
For the size of wood you are talking about, I'd drive 4 1-1/4" screws and use the tailstock. More and longer would be better, but 4 will hold...
Steven
Dick Hines
Re: #10 and #12 Pan head Square Drive....
Dick Hines
>I don't use my face plate much, but when I do I use hex head self tapping screws. 1/4" drive and just small enough to fit the face plate holes.
Re: I like Spax screws
Paul Zerjay
>Strange how different terminology around the country is. I've been in the construction trade for close to thirty years and I have no idea what a Spax screw is.
Re: Almost any screw.
Carole Valentine
>If you have been using drywall screws, I would say you have been lucky. they are not very strong at all. I like the sheet metal screws that I can drive with a socket.
Bill Crommett
>If all you good people haven't confused Wilbur, nothing will.
Wayne Kuhn
>Mcfeelys makes a great screw, I use flat head, square drive pocket hole screws. # 8 x 1/12 I believe. Pocket hole screws actually have an edge on them to drill the pilot hole. They seem to last forever.
I use a battery drill with a long (6") bit to insert them. I only drill a pilot hole in really dense woods.
I never use Drywall screws, too brittle.
I use a Don Pencil face plate & 4 screws.
The body of the screw (treads) should just match the diameter of the hole in the face faceplate to keep your workpiece from shifting around. If you pay attention to this detail you won't have to torque the screws down super tight.
Bill Crommett
>By the way, I use hex head sheet metal screws and lots of them. Most all of my face plates have extra holes that I have drilled for more screws.
