>I'm rearranging my shop...getting rid of some stuff, making room for other stuff. I have a Jet mini on a bench and a Jet 1442 included in the mix. I'm curious...where do you have your lathe located? Parallel to and against a wall? Perpendicular to a wall? Out in the floor so you can get to both sides? Why did you choose that location?
>I have my lathe (1642) parallel to an exterior wall, right in front of the window. I chose to put it there because I like to use natural light upon occasion and I like to put a fan in the window for ventilation when I'm finishing on the lathe.
I have it out from the wall a bit so I can vacuum upon occasion.
The only drawbacks are that I do have to remember to put the window shield up on the rare occasions when I do bowls and one of my cats likes to perch on my drawer box when she's looking out the window. She also likes to snatch my rubber band "cushions" that I use when I use my chuck :).
>Open to turn from both sides. Seems silly to only turn from one side unless you don't have the room. Mini on the bench with mini-bandsaw and drillpress. Floor covered with woodchips and dust to keep the delicate ladies away. All woodturners welcome!
>I've been out of town for a week. Should I go look? It didn't leave while I was out did it?
Mine is against a wall with a window above. It might be better if it were out in the floor, with space behind it, but I have a small shop. I would not want it end wise to the wall unless there were enough room to insert the knock out bars, etc.
I suppose you could put it on a mobile base, but my cabinet has about four hundred pounds of sand in it, plus the cabinet and all the stuff in it, plus the lathe. Probably seven hundred pounds all told. it would have to be a pretty heavy duty base and it would have to set the lathe down solidly.
>I have mine against a wall to contain the shavings and because there's power there!
It's actually about 3 feet from the wall to make sweeping behind it easier. The headstock swivels, so I don't worry about standing on the right of the ways.
I placed it at the door end of the garage, and I can open the door to get all the natural light and air I need. Also, puts me closer to the outside when it comes time to clean up, which is whenever I feel like it but certainly not every day.
>My mini is parallel to a wall and about a foot out from the wall. No reason to have it taking up more space than that.
My Robust is slightly angled out from a "wall" (old bookcases with solid backs). I need more room at the tail stock end because I like to turn bowls bowl-lathe style.
>My lathe is faceing the wall of my garage shop right next to the roll up door. I get lots of light when the door is open and in the summer I hang a fan to the left of the head stock and blow cool air right where I am standing. The fan is quiter than the DC too.
There is enough room behind the lathe so I can turn from the back side if need be.
>My shop is a 10' x 20' garage and my ova 1624 is located midway along the back 10' wall, perpendicular to it. This way I can access both sides and while I don't do it often, it is nice when I can. I've got a shower curtain hung behind me and will soon put on on the backside as well, to help contain the shavings.
My biggest obstacle in my shop is my bench. It was made for handtool work and is big, bulky and weighs a ton. I think I would be better off with something 18" deep and around 6ft long to support, well, you know, turning stuff!
>I no longer do any flat work, so my lathe commands the middle of the shop. I work from all sides and it just seem the best fit for me.
I know I am lucky to turn full time. But if I ever felt like I had to turn with shower curtains around me to contain my mess, I just could not do it. It would feel to much like a cubicle to me. I also enjoy finding shavings in the far reaches of the shop when I do a major clean up. :)
2of the three I Own are situated in a corner of my shop at right angles to each other si I can sit on a stool and switch from one lathe to the other when I am working on different pens at the same time.
One is a Rikon and the other a Jet mini.
The Jet is elevated so it is the same height as the Rikon.
The shop is too small to give up wall space for a luxury of a window.
>Parallel to the exterior wall for light. About 1' away from the wall to vacuum. Need a bowl launch protector for the windows though. Have been lucky that they have either hit the windowsill or rocketed off the wall and landed in the bathroom.
Garage is the better half's woodworking area and is taboo so being the delicate lady of the house I opted to turn the spare bedroom into a turning room.
>I have one of the smallest work spaces around. It is a converted walk-in closet in my apartment. My Jet mini VS is positioned at an angle to the back wall so I can stand at the end while hollowing.
>At one end of my kitchen, parallel to the wall. Best lighting comes from the door, which I keep open to the sun and air whenever I can. (No garage, no basement to speak of... no spare bedroom just yet.)
>In the garage at the front bumper of the car. Usually the car goes out into the drive, but I have been known to cover the hood with a moving quilt and go for it. But then I started launching bowls. First I moved the car outdoors. Next I ducked. Then I decided I was getting too old to keep ducking, so I learned how to NOT launch bowl blanks! LOL!
>of the shop, where I can get to both sides and the ends. I did it that way, because my air cleaner is directly over the headstock end, and so I could turn from both sides, and the back side of the headstock. I do a lot of turning from the off side of the lathe.
My little Vic VL100 is on a bench four feet away from that.
If I had it to do over, I would still have it centered in the room, but I would put it a little closer to the exhaust fans in the end window.
>Until I get my shop built, my Jet 1642 is in 1/2 of a two-car garage. Although the lathe is basically in the center of the room, in effect it is up against a "wall", but functionally it's in the middle of a tight u-shape surrounded by everything I need within arm's reach (more or less).
The quick rendering below is of the basic layout, however, there is much more. When I stand at the lathe, the bandsaw and storage cabinets are directly behind me, a Jet mini is back to my left, back to my right are more shelves with power carvers/sanders and accessories, to my left is a roll-around cart with drawers and finishing supplies, and next to that within a few steps are the large toolboxes. Under the lathe are two plastic bins that catch shavings.
The "wall" just behind the lathe is just a piece of 3/4" plywood with hangers for calipers, tool rests, and other things plus shelves, rack, and bins for drive centers, sandpaper, etc. To it's right are shelves with most of the cutting tools, the tall shelf unit holds long cutting tools plus chucks and more, and the table is for sharpening and to lay things down temporarily. I place all lathe cutting tools with the sharp ends towards me so I can see at a glance which is which.
What's also not shown is the lighting - as well as overhead lights, I have numerous clip-on reflectors with a mix of both incandescents and bright compact fluorescent bulbs.
I've tried several configurations and I LOVE this arrangement. The best thing is that almost everything that I access frequently is within arm's reach with very little wasted movement.
When I built the shop I added a computer area and a sleeping loft above that. The pic is from the window in the loft area. This is one I posted before in response to a question about shop lay-outs. It seemed the best way to get an idea of how I have mine set up.
