Macadamia Wood
LP Skendzel
>I have branches of macadamia I would like to use for inlays on woodturnings. They are green and when I make buttons for inlays,they crack. What is the secret to drying macadamia wood?
Thanks for any assistance.
Macadamia Wood
LP Skendzel
Re: Macadamia Wood
>I don't know anything specifically about Macadamia wood, but I know a few things about wood.
If you are slicing buttons by cutting the limbs straight through making cross sections like slices of salami, they will almost surely crack. They would contain the center or pith of the limb and as the outside dries and tries to shrink, the center would tend to remain wet and swollen, thus the outside would have to crack. Also limbs may contain reaction wood, meaning the characteristics of the wood on the top side of the limb and bottom side are different. The top side is grown in tension and the bottom is in compression. You need to split the wood down the center, let it dry and then slice pieces out of the halves.
It might be possible to stabilize the wood by saturating the pore structure with something like plastic, that is then hardened. If this is important to you, investigate "Stabilizing".
Re: Macadamia Wood
david
>I have turned a few pieces and they all cracked. Fellow in my club gets great results. He said the secret is turning the wood green (when dry it is almost impossible to turn) and when fine cracks appear he hits the cracks with thin CA glue. Sometimes several times a day until the piece is dry. I am not able to baby sit my pieces like that, so they have cracks. Surely not because of my deficiencies as a turner...
Re: Macadamia Wood
LP Skendzel
>Barry, Thanks for the suggestion. I will try again and follow your recommendations. I will let you know of the results.
Re: Macadamia Wood
LP Skendzel
>Thanks for the suggestion. I need to have cross-sections to demonstrate the ray pattern.
Re: Macadamia Wood
LP Skendzel
>David, thanks for the advise. I turned a few buttons yesterday and immediately applied a thin layer of the glue you recommended. This morning, there are no cracks but now I have to deal with the glue coating tine surfaces. I'll keep you informed.
Larry
Re: Macadamia Wood
LP Skendzel
>Hi, David,
The buttons did not crack until I made inlays in a piece of wood. Then, they cracked and some did shrink.
Somehow, the wood has to dry but how to accomplish this without cracking is another matter.
Regards,
