sanders
jimtex
>i have another dumb question. what kind of sanders do ya'll like? my callouses have blisters. i turn small stuff like boxes and would like to speed up the sanding a little bit. thanks, jim
sanders
jimtex
Re: sanders
Barry Turner
>I power sand with 2" foam disks with velcro. I spin the disks with an old 9.6 volt, Panasonic cordless drill.
Re: sanders
Roger Dunn
>I use:
1. a Metabo 3" random orbit sander with Hook and loop discs
2. Milwaukee 1/2 " angle drill with 2" and 3" H & L pads.
3. 3/8" drill with a 6" extension to get 2" and 3" H & L pads to the bottoms of deep vases.
4. Bosch 5" ROS for large pieces in the lower grits.
Hand sanding takes tooo long.
Good luck
Roger Dunn
Re: sanders
Ed Karch
>Air right angle die grinder with sanding arbors and pads.
Re: sanders *LINK*
>I hand sand my boxes. I've concentrated hard for the last bunch of years learning to cut to reduce the sanding time. I can usually start with 180 or 220 and then finish up to 400 or 600. I don't have a power sander that will get inside most of them anyway.
On bowls I use a regular Dewalt 3/8" drill and have 2" sanding discs that I got from Vince. I've thought about the angled drills but they are very expensive and don't seem to hold up as well as my $64 dewalt. I bought an air sander but don't have a compressor large enough to use it. I do use it some but try to stop before I burn up the compressor. Air sanders are nice, they are light and powerful but incredibly noisy, at least the cheap one I own is.
http://www.vinceswoodnwonders.com/
Re: sanders
robo hippy
>I reguard the power sanders as some thing to use on bigger bowls, and things with smooth surfaces (no beads or coves). For smaller things like boxes and spindles, I hand sand. If you are getting blisters, it could be caused by sanding at too high of a speed, putting too much pressure on your abrasives, or a combination of both. Light pressure and a slower speed (500 rpm or less) works better than the higher speeds, plus you don't generate the heat that can damage the wood. If you are getting heat through the abrasive, you can fold the paper a couple of times, or I have even used the soft foam pads that I attach my discs to. Having fresh paper helps, dull or clogged paper will not cut, and will generate more heat. Of course, there is a lot of difference in the abrasives that are out there. When I do power sand, I like the angle drills from Sioux/Milwaukee. They really speed up bowl sanding. They cost more, but will take more abuse than the cheaper models. Apparently, Milwaukee has come out with their own version of an angle drill that is now different from the Sioux drill. Oh yes, the best thing to do to reduce your sanding chores is to improve your tool skills and techinque.
robo hippy
Re: sanders
Allen Neighbors
>Jim, I use homemade sanders made from used rollerblade wheels. I epoxy a 1/4" x 6" long piece of allthread into the bearing. I glue a pad cut from an old flipflop shower sandal to the wheel with contact cement. Then bend the allthread to a 45 degree angle, and glue on a piece of 3/4" dowel pin for a handle.
I glue the industrial 2" wide velcro onto the pad, and that's what the velcro discs stick to.
You can turn the wheel down to any diameter you want... depending on the size of the wheel... using an 60 or 50 grit sanding belt, and holding the wheel at an oblique angle to the direction of the belt.
One pair of used rollerblades from a rummage sale will net you 8 sanders. Most of mine are 3" diameter, but I have a 2" and 1-1/2" to get into small places.
I use 3-3/8" velcro disks from Vince's Wood'N'Wonders, and cut down the ones for the smaller sanders.
Works for me.
Oh, I also have a Sioux angle drill that I use on bowl interiors.
Re: sanders
Ric Taylor
>John,
I use an air sander for power sanding, and I don't even have a compressor. I just bought the cheapest one I could find at Harbor Freight (I think it was $19 on sale at the time), put a 2" pad on it, and let the lathe rotation power it. Works great, it's not noisy, and if I ever get a compressor, I already have one of the tools.
Ric
Re: sanders
BobM
>I use a Metabo 3" random orbit sander with Hook and loop discs
and a Milwaukee 1/2" angle drill with 3" H & L pads. I also use a soft pad for a 6" random orbital sander and cut it into 3" disk to use on either sander when I want a less aggressive sanding surface. I hand sand when necessary with the lathe off. I use Klingspore Gold sandpaper.
Re: sanders
>I didn't like the non powered sanders for use on my hand mirrors. they didn't seem to sand the middle very well. I hand sand those as well because I often put crisp details where beads or coves meet the body and you just can't power sand those and keep them crisp.
Re: sanders
Ric Taylor
>I agree..... around details, hand sanding is the only way to go.
Ric
Re: sanders
keith zimmerman, Normal, IL
>I use a 3/8" angle drill with Vince's 2" disks for power sanding. I always handsand boxes and use Norton 3x torn into eighths. On very small boxes, I will use some 1 x 1 1/2" strips of Vince's. With the cutting techniques I have developed, I usually start sanding at 180 grit. I always slow down to 500 rpm on my Jet mini VS.
As others have said, if you're getting blisters, you're either using too much pressure, or sanding too fast, or both.
keithz
Re: blisters and sanding
jimtex
>the blister's were an attempt at humour! thanks though for all the advice! i think i'll try the drill and attachments before i go buy something i'll soon regret. i don't have a real problem on the outside of my boxes, it's the inside that have me frustrated. i'm not really a perfectionist,(despite what my wife say's), but i want the inside and bottom to look as good as the outside. thanks again, jim
Re: sanders- I use inertia sanders
georgetroy
>The inside of boxes is when I always burn my fingers. I try to fold the sandpaper to absorb the heat but every now and then on the 400 or 600 it gets you. It happens so fast. I hate it when it does that.
No one posted this method, so...
david
>I saw another turner do this, and thought it worth copying. I have disks for power sanding, but use abrasive sheets a lot. To cut the sheets, I mounted a bandsaw blade on one edge of a piece of plywood, with pencil markings for where to position the sheet to rip it in half, then a quarter. I used a small flat washer on each end to elevate the blade a bit to slide the sandpaper sheet under easier. I then found a piece of leather and cut it to the size of the quarter sheet folded in half. The leather backing the folded sheet is flexible enough to conform to the bowl contour, and provides enough insulation to keep my fingers from getting hot or burning. After one side is clogged, just flip the paper over and work the other half. Only disadvantage is that you can make the piece very hot and some varieties of wood will not hold up to the heat build-up.
