Chain sharpener
Chain sharpener
Chain sharpener
Bill Hale / The Wood Spinner
>I want to buy a good power chain saw chain sharpener. I want the bench mount type like they have at the chain saw shops.
Between our landscape business and mine we do about 20 per year.
I bought one from Harbor Freight and took it back. $ 100.00 range is no problem.
Thanks Bill in CG, AZ.
Re: Chain sharpener
Re: Chain sharpener *LINK*
>Try Bailey's, under Chain Grinders. Good company.
http://www.baileysonline.com
Re: Chain sharpener
Re: Chain sharpener
david
>Thanks for the link. However, so many options produces some questions. Which type would you recommend? The hand-held ones seem to be not much different than a Dremel or Proxxon tool. The type that attaches to the bar looks like what I would be interested in, but have not had any experience with it.
Re: Chain sharpener
>Bill, I bought my chain grinder from Madsen's. It's similar to what Bailey's sells as "Speed Master" but is a bit heavier and offers compound angle adjustment. Brand is Tecomec FL 136 and the cost was about $230 3 years ago. Great grinder. Very precise so it lets me just kiss the chain to sharp without grinding off half the damn tooth or bluing the steel. Its geometry is also very good so that I don't have to reset the depth stop when I switch sides on the chain. This is very important to keep the grind even and the chain balanced. I use a compound grind of 27� x 62� and my saws fly through eastern hardwood.
Madsen's doesn't have an online catalogue anymore, but the link will get you to them on an 800 number. Good people, very knowledgeable.
MM
Madsen's
Re: Chain sharpener
Re: Chain sharpener
Paul Zerjay
>Thats funny about the Harbor Freight model. My neighbor and I both heat our homes with wood. We go through close to 11 cords each yearly. We are both firm believers in Stihl saws. But, he has a harbor freight sharpener, and I take my chains back to the stihl dealership to get them sharpened. He always makes fun of me for wasting money on sharpening, but I go through red oak like a hot knife through butter, while he's back in the garage "sharpening" his chains!! HEHE
Re: Chain sharpener
Re: Chain sharpener
Bruce McElhaney, Spring Lake, Michigan
>I've tried a lot of different chain sharpeners over the years, but now I'm using a cordless Dremel tool. I use Dremel's optional, chain sharpening kit (about $15.00) It works great in the shop or in the field. . . Quick accurate and makes a very sharp chain.
Re: Chain sharpener
Re: Chain sharpener
>>...Which type would you recommend?
I personally sharpen by hand with a file and use a stone in a Dremel if I need to repair teeth damaged by a rock or metal embedded in a tree. Both of these methods take a bit of skill but nothing the typical woodturner couldn't learn with just a bit of direction and practice.
The bench type that Baley's and others sell is the type used by the shops around here. I haven't used it either, but from what I've seen, a trained chimpanzee could set up and use one.
Re: Chain sharpener
Re: Chimps or Chumps
>Reason I started doing my own chains was after assorted deadbrains at various local shops, including a Stihl dealer, wasted several of my chains. Took huge amounts off (sell more chains that way) blued the teeth with over heating (wrecks the temper - sell more chains that way) and ground the cutters longer on one side than the other (cuts curves - sell more chains that way).
These idiots would get 3-4 sharpenings and the chain was done. Each of my working chains have been sharpened between 7 and 10 times and still have more that 50% of their cutter size left. Takes me 10 minutes to do a 16" chain, 20 for a 28. No bluing. Just sharp. Plus I can match the grind to suit the wood being cut; shorter point for hardwood, longer for pitchy soft woods. I don't bother with files (except for the rakers) as I take 3 or 4 sharp chains for each saw when I go a'cuttin'. One goes dull or wanders in a cut, off she comes and into the sharpening bag.
mm
Re: Chain sharpener
Re: THANK
>I think I will give the Dremmel a try. If I don't like that a full size power unit.
Thanks again
Bill
