Help!! Hunter Tool stuck!!
Allen Neighbors
>I need to rotate the cutter on my Hunter Tool. I tried the little plastic handled tool that came with it, to loosen the screw holding the cutter. It wouldn't budge. I put the tool shaft in my vise, pressed down on the tool, and tried to turn it with pliers, and it still won't budge. Now I think I've stripped it out so that nothing will work.
Any suggestions?
Re: Help!! Hunter Tool stuck!!
Steven Antonucci
Try the usuals
steve antonucci
>Penetrating oil first.
I don't know what the screw is, but if you get desperate, you can cut a slot in the top with a dremel and a cut-off bit for a flat headed screw driver or just cut the head off, since you've got to replace the screw anyway.
I doubt the cutoff wheel will even dent the carbide cutter.
Steven
Boy, Am I Glad
>That I greased the screws that hold my cutters. I was a little concernind that they might rust in place working with juicy tannin-rich wood. Seems I made a good choice.
Alan, I'd work some penetrating oil in from the bottom of the screw hole and make sure the torx cup is clear to the bottom. If all else fails, you're going to have to carefully drill that screw and use an easy-out. Problem is, I think those screws are grade 8 and hard, so the dril thing is a last resort.
post your successful method.
mm
Ron in Drums PA
>The driver size is a Torx 15.
I have a handled set and a folding set similar to a set of folding Allen wrenches. I picked up the set up at Sears for $5.
Sears item# 00930527000 Mfr. model# 30527
Do you have a set of screw extractors?
Re: Try the usuals
Allen Neighbors
>Steve, the screw head is about 1/16" in diameter... we're talking small! And it's countersunk, down inside the cutter. Penetrating oil doesn't do it. Thanks for trying.
What size is the cutter? Sounds like a #1.
keith zimmerman, Normal, IL
>Allen It may take a day or so for the penetrating oil to work. It is a tapered screw and fits a tapered slot. You might want to get a good quality T15 screwdriver so you can put a lot of pressure and keep it square to the head.
Re: Boy, Am I Glad
Allen Neighbors
>Mark, you were smart to grease the screws. I wish I had. I always blow the head of the screw out with a blast of air, and put the little plastic guard back on it, after every use. But putting the little cover back on may not have been such a good idea.
I did make sure the screw head was clean with a needle point awl, before I inserted the tool.
Thanks. :)
It is a #1, Keith.
Allen Neighbors
Allen Neighbors
>No, I don't have any screw extractors. I do have eze-outs, but the screw head is smaller than any I've ever seen.
Thanks for giving me the correct size of Torx, Ron.
Allen Neighbors
>Thanks, John. Now that I know the right size to get, I'll try to pick one up tomorrow, if I can even find one in this small town. I hate to spend the diesel to drive 70 miles to the next town of any size. I'll just keep putting the Penetrating oil on it, until I can get the right driver.
Steven Antonucci
Truly desperate measures
steve antonucci
>I once snapped the head off of a bolt on a valve cover on my Chevelle. Ok, I actually did it twice.
When I removed the cover, all that remained was the threaded part of the bolt. I drilled down the center with a smaller diameter bit and hammered an alan key in. Then, very carefully, backed out the broken stud.
Might also want to try a little bit of heat to "burn" any of the crud boogering up the threads.
Steve
Re: Truly desperate measures
Allen Neighbors
>I wonder how much heat, before I harm the cutter?
Bill Crommett
>Al: Just warm up the end with a torch enough so that when it cools the penetrating oil will get sucked in.
Mike Hunter
Mike Hunter
>Allen
Our WoodCentral friends have posted about all helpful hints. The penetrating oil, with a little heat, allowing time for the oil to seep into the threads is all good advice.
Please send a seperate email with your address, and I'll send you a replacement screw and torx wrench.
It might be good to confirm the diameter of the cutter. What size is the shaft the cutter is sitting in? If it is 3/8 or 1/2 then the torx wrench is a T-15. If it is 3/16 square or 3/16 round, then the torx wrench is a T-7.
Mike
Way Easier
>Steve, to use an easy-out screw extractor. Looks like a tap but with a reverse thread. Drill the stud, turn in the extractor, and the screw breaks loose and is removed.
Try one; you'll like'em. Beat the snot out of an allen wrench.
BTW, who was "allen", and did he ever get treated for the hexagon fetish he had?
mm
Allen Neighbors
>I'll give it a try, Bill, Thanks.
Re: Way Easier
Allen Neighbors
>Mark, I'm Allen. And I didn't know I had a hexagon fetish.... ????
Allen Neighbors
>Mike, this is the one you brought to me at SWAT, that has the cutter on a 1/4" round shaft about 7/8" long. Remember it? I think it's the #1, but I can't be sure. I think the cutter is about 3/16" diameter. Very small, but a cutting machine!
Email sent!!
Allen Neighbors
Mike Hunter
Mike Hunter
>Allen ... with that reminder, I do remember, the cutter is a # 1 and is a small cutter. The torx is a T-7 with the small screw. Please send your address and a "surprise" will be in the mail. To confirm, that was a 1/4" round shank vs the 3/16" round shank?
Allen Neighbors
>Torx size 7. Thanks. Yes, it is a 1/4" round shank.
I like the round shank, for mounting in my 1/2" or 5/8" tool bars. The larger bar makes it reach farther across the rest without chatter, for finishing cuts in longer narrow vessels. I love it. I use the set screws that fasten the tool bar into the handle to know what the angle of the cutter is when I can't see it.
Walter Ahlgrim
>Not all penetrating oil are the same you want a spray can of �PB Blaster� go to the auto parts store.
Walta
Keith Tompkins
Re: Boy, Am I Glad
Keith Tompkins
>Allen, put the tool handle in a vise,then turn the whole cutter with pliers wrapped in something soft like leather to protect the cutting edge. the screw may back out when you rotate the cutter...
Going forward...
Peter Teubel
>As a former shade-tree mechanic, I had a saying..."NEVERSIEZE EVERYTHING". It's that silvery goop used to prevent corrosion and galvanic reactions (common with dissimilar metals in contact with one another). If you have a screw or bolt that you MIGHT someday need to remove (and it's in a corrosive environment), dab a little Neversieze on it. It'll make removal not only possible but much easier.
Personally, I always wanted to put Neversieze and LockTite on the same bolt and let'em fight it out...
