A55 Smoothing Plane
Sharening tools using the lathe
Jeff L
>May be a dumb question but can one use the lathe to sharpen ones tools? Can a grindng wheel or somethng be attached to the chuck? I have not seen any discussion of this. If it can be done, what is the best method? What grit would be the best?
Thanks
Re: Sharening tools using the lathe
Bill Hale / The Wood Spinner
>Yes
Bonnie Klein does it all the time in her demos.
She has grinder and buffer that she attaches to the spindle.
Good turning and be safe
Bill in CG, AZ.
>I haven't done it, but I've seen where people have sharpened with a disk of sandpaper glued to a piece of plywood on a face plate.
Steven Antonucci
I haven't gotten to it yet, but it's on my list
steve antonucci
>I don't own a grinder, but I have a small grinding wheel that I wanted to mount on my lathe for the occasional heavy grinding need I encounter. I envision having a work arbor on a #2 Morse Taper with the wheel being held up by the tailstock live center.
I think having 8 speeds available will help with the wheel being out of ballance, and I'd cover the ways with a sheet of flashing to prevent any damage or debris accumulation. I would also sweep the area clean and vacuum to prevent any fire problems. A tool rest will probably suffice as a work surface for rough grinding, but I wouldn't want to use it for sharpening.
Steven
I Did That Back In 2003 *LINK*
Barbara Gill, Remlik VA
>Check out shop Shots.
Outboard Sharpening
>Jeff I used to do it all the time. I had a sanding disc I would put on the lathe. I also use that method when I go to my dads. He has a shopsmith so we just but the sanding disc on the outboard side. l
Sears sells a 1/2" chuck with a morse taper that also accepts grinding wheels. When you remove the chuck it has a 1/2x13tpi thread and comes with washers and a nut . It is also threaded on the end of the morse taper to accept a draw bar. If I remember correctly it was really inexpensive. The guys at Sears don't even know it exists and it's hard to find in their catalog. It was listed with the wood lathe accessories.
It should be obvious but if you grind on the lathe cover the bed. You really don't want all those abrasive on there.
Re: Sharening tools using the lathe *LINK*
>It's shown in this photo so maybe they still sell it seperately.
http://www.sears.com/shc/s/p_10153_12605_00921720000P?sbf=Brand&sbv=Craftsman&vName=Tools&cName=Bench+Power+Tools&sName=Lathes
Mike Brazeau
>About 7-8 years ago I saw a sharpening/honing disk demonstrated by Sorby at a wood show and made a similar setup. I used 120 grit cloth backed sandpaper glued to a disk about 4-5" in diameter with contact cement. For rough grinding I used 80 grit. The disk has a tenon glued on the back which mounted in the chuck. Glue the tenon on and then true up the disk before attaching the sandpaper. Works OK when you have no other alternative, but mainly for touching up an existing grind. Shaping is somewhat difficult. I also made a disk with leather bonded to it and used abrasive in a tube from Tormek for honing, which I still do occasionally. The Sorby system had teenuts for mounting. I tried that but found the chuck and tenon method better.
Stuart Johnson
>Is it safe to have an exposed wheel? There have been a few cautionary tales about cracked wheels exploding and the danger involved.
Re: Considering that you can buy .......
Jamie Donaldson
>...an excellent dedicated grinder from Woodcraft for about $90, I wouldn't recommend the hassle and possible danger of improvising a grinder mounted on the lathe. It would often require dismounting the work piece in order to grind, and that alone is more trouble than it's worth. I have seen grinder wheels mounted outboard, and the turner being injured when absent-mindedly grabbing the rotating grinding stone thinking it was a hand wheel,and it's not a pretty sight as well as a very painful wound!
you can get a grinder for $30
>A friend who just got into turning on a tight budget went to Big Lots and bought a grinder for $30. It's decent enough to sharpen lathe tools with the stone that came with it. I gave him an old starwheel I had to clean the wheel often. I used a grinder like that for years. Granted the new grinders with white wheels are much better but the old ways are still serviceable.
Jeff, I have a .pdf file of...
Allen Neighbors
>my Travel Buffer/Grinder system that I use on my Vicmarc Mini Lathe. If you'll email me, I'll send it to you.
I mounted the stone on a permanent block that clamps in my chuck, and is supported by the tailstock. Also, I have an adjustable arm underneath the lathe ways that I use with a homemade varigrind (actually, it's a "doesn'tvarygrind") for my bowl gouges.
Jeff L
>Thanks for all the input. I am new to this forum and with most other forums usually only get a few responses. The response from you was more than I expected. Thank you
check Lee Valley *LINK*
Steven Kubien
>Lee Valley also sells this #2MT-with-the-threaded-end-and-washers set up. Item # 50J5101. Might be nice to get it on its own instead of with a bunch of other stuff you may or may not need.
Steve Kubien
Morse taper mandrel
Penn State Industries...
Clem Wixted, Jonesboro, AR
>...used to sell a plate that mounted behind a chuck on the spindle. The plate had sandpaper mounted to it and was used to touch up a gouge while turning.
I made a 5" aluminum plate with a 1' hole in it and put PSA on it for my Jet mini. Works like a champ, especially if you do demo's and don't want to drag a grinder around with you. I am thinking of putting a different grit on each side.
Clem
ReSharpening tools using the lathe
>I have a half inch mandrel with a No. 1 Morse taper left over form when I owned a Sears lathe. I have an adapter that lets me use it on my current lathe. I don't think I have put a grinding wheel on it, but I have used it with a nylon mesh abrasive wheel.
So, Yes you can do it. But, it would be a PITA as mentioned by others. Think about it. You usually only want to sharpen when you are turning. You would have to take the work off, install the grinding setup, sharpen, remove the grinding setup and reinstall the work. Not worth it.
Did anybody tell you that the lathe was the cheap part? Welcome to the slippery slope. The accessories and the ancillary stuff will cost much more. Get a grinder. I made jigs for mine. Another decision. Make jigs or buy them?
Re: ReSharpening tools using the lathe
David Walser
In most circumstances, I would agree with you. I disagree in the context of a portable woodturning kit to have on vacation, at a show, or at a demo. In that context, you have to compare the inconvenience of removing an item from the lathe in order to sharpen a tool with the hassle of lugging around a grinder. If there's no room for a grinder (in your trunk or where you're setting up your lathe), the ability to turn your lathe into a sharpening tool may be the difference between turning or not turning at all (once your tools are dull).
I realize not everyone travels with their lathe. (I don't.) For those who do, carrying a grinding wheel and arbor might be a real space saving convenience. I wouldn't recommend it at a permanent solution -- just as I wouldn't want to use my camp stove on a regular basis. As a temporary fix, this lathe-as-grinder idea is pretty doggone cool.
Jeff L
>If I buy grinder, what grit wheels do I need? Is the slow speed grinders the one to buy?
eliot d
>It's not a dumb question. If you really like the idea of sharpening on fast-moving sandpaper, look into the JoolTool. Basically , it is a variable speed motor, with a very high max speed, onto which shaft you can quickly thread on various so-called "Ninja" sandpaper-backed disks. They are called "Ninja" disks because they look exactly like those martial arts throwing discs you see on TV martial arts programs. The idea of the Ninja design is that they have open places that you can see through when they are spinning. They spin in a horizontal plane, and you bring the tool you want sharpened up toward the spinning disk until it just "kisses" the rapidly-spinning disk. You can see the edge as is is sharpened. The sandpaper disks come in grits starting at 60 grit and going all the way down to 5 microns. There are also diamond -backed disks, and other specialty disks for polishing, etc. You see the Jooltool lady, Annie, at the woodworking shows demonstrating and selling the unit. You can find her online, too, by entering Jooltool, or something like that. I have one and love it; but it's not all that easy to use ,and it's not cheap. There are no jigs; you have to learn to do it all by "hand". I love to touch up tools , already shaped and sharpened, using the really fine disks. The diamond disks are perfect for supper hard steels.( I have no affiliation with Jool Tool.)
Um....
wilbur
>Um, am I the only one that thinks that getting grinder wheel and metal dust on the ways of the lathe, and maybe into the headstock bearings, might not be such a great idea?
Re: Jeff- the Woodcraft low speed.....
Jamie Donaldson
>....grinder comes with a 60 and 100 grit Alum.Oxide(white)wheel set that is a very good combination for most tool sharpening. I use a 120 grit rather than 100, but that's a personal choice for smaller tools.
I agree, David. When I
Allen Neighbors
>travel to Craft Shows, or even just to get away for a while, we're usually packed to the rafters, and don't have room for my delta grinder. By marking the No. 1 Jaw on my chucked piece, it's no hassell to remove it, install the wheel, sharpen, and re-chuck the piece. My wheel is supported by the tailstock, and when I get the guard designed to go in my toolrest, it'll be just as safe as the normal grinder.
Wilbur, an oilcloth tablecloth...
Allen Neighbors
>from Walmart is easy to throw over the ways and motor on my lathe. I always have compressed air to blow away the dust. Also, I don't see how the dust can get into the headstock, with sealed bearings. I may be wrong, but I don't think it can. It would be easy to just put a piece of duct tape on the headstock, and protruding out over the spindle shaft, also, if you'd be worried about it.
I agree...
Wally Dickerman in Arizona
>Yes, Bonnie Klein uses a grinding wheel attached to a lathe for demos because it's convenient. I've done demos where there wasn't a grinder available. You can be sure that in her own shop Bonnie has a regular grinder.
I agree that regularly using a grinder attached to the lathe is a bad idea. It does leave a mess of steel and grinder wheel residue. Also, the protective cover on all grinders is there for a reason. Grinding wheels have been known to fly apart.
Wally
Barbara, Do you still have the Merc?
Allen Neighbors
