Re: Lathe Choice
Fog Tanner
>My first lathe was the 16" Delta steel bed lathe. I liked it a lot, except for the sliding headstock. I was doing both spindles and bowls, which it would handle with no problem. The reason I wouldn't get another sliding headstock, was during coring the headstock would come unlatched and that is not a fun expereince.
I got into off center turning and found the limits of a 16" swing pretty quick. I started looking at larger lathes and contacted a number of the professionals I have met asking their opinions since they use them to make a living. I would up getting a Vic 300VL long bed. Its 1000lbs of lathe.
After getting the machine, I found out why you always see Raffan, Mahoney, and Key using them in their videos. Without changing anything else, my work was coming out better. The machine is a lot more solid than the smaller machines. So, their work will look better on camera and they don't have to fight a small lathe.
If I had it to do over again, I would have gotten a mini lathe to start with, saved my money and then gone from that to the Vic. If I get another lathe, it will either be the Vic 300 short bed, the larger Vic that they are working on, or build one myself. While the larger machines are outside your current price range, they really aren't in the long run. Even if its "just a hobby", life is too short fighting a small machine.
