jet JWL-1236 lathe
jet JWL-1236 lathe
jet JWL-1236 lathe
Glenn K
>I am very new to turning. I purchased a jet JWL-1236 lathe that seems to fit my abilities well. Recently I had trouble with the speed control, the lathe does not want to turn slowly. I removed the cover and it seems that when the control lever is rotated that only one split pulley is changing shape and the belt is just spinning loose on the other pulley. Has any one had this problem before and how did they solve it. Any help for a novice would be appreciated.
Re: jet JWL-1236 lathe
Roger in MO
Roger in MO
>Glen, I had the same problem when I first obtained my used 12/36. In normal operation as one sheave expands the other closes. Try tapping (lightly) the sheave that has compressed a spring to see if it will slide. Do this with the lathe turned OFF.
If I leave the lathe in a mid speed range when I turn it off, the drive will work OK when I turn it back on, even if it hasn't been used for a while. If I leave it in low, often the sheave sticks.
Powder graphite might work as a lubricant. One of these days I'll get around to disassembling the drive and clean it up. Mine won't stay is the very lowest setting.
Roger
