comparisons of articulated arm hollowing systems
Dave L
>Can anyone compare the KOBRA SYSTEM with the "MONSTER Articulated Arm System" offerred by Monster Wood Tools? Looking at the sites It seems that one would get more accessories with the Monster system. Can anyone offer the pros and cons of the systems to help in my decision making process. Thanks in advance.
Dave L
Re: comparisons of articulated arm hollowing systems
Andy DiPietro
Andy DiPietro
>Hi Dave,
I have been using the Monster Articulating system for about a month now and I am really pleased with it. I have read good reviews on both systems and I am sure they both work well. The most important feature and the main reason I choose the Monster system is that Randy Privett uses an industrial laser with a remote switch. I have burned out five pen laser on my other systems do to vibration and I am tired of buying more. His laser solves the problem. The other reason is you can not beat his price especially with the array of included attachments IMHO.
Andy DiPietro
Carol - now in NC Nebraska
>The Kobra is such a new system that I am thinking few people have had the opportunity to use both and make a true comparison. So when hearing comments, beware that by comparison, few have had actual hands on both and may be making comments based on opinion rather than experience.
Otherwise you may well be hearing an apples vs. oranges comparison.
Don Geiger
Don Geiger
>I have not used the Monster, but Indiana Innovators (rayt@indy.net), the makers of the Kobra articulated hollowing systems recently provided me with a red Kobra for my Stubby Lathe and a green Kobra for my Jet mini lathe for evaluation.
The larger red one can be supplied for almost any size lathe. The smaller green one is built specifically to fit a Jet mini lathe, but can be adapted to a larger lathe by purchasing the appropriate adapter system.
I�ve used many different hollowing systems in the past. The Kobra offers several advantages over them. Some of these advantages are:
- The Kobra is a bed-mounted multi-axis (4) articulated system designed to arrest the torque when hollowing. There are a total of four joints, each with needle thrust bearings. When shipped to the end user, there is no discernable play in the joints either individually or combined. The tension of each joint is adjustable.
- The vertical position of the system is easily adjusted to match your spindle height.
- The large red Kobra system had a 1� diameter hole with two set screws used to receive and secure a boring bar. The Green smaller Kobra has a 5/8� diameter receiver. There are optional adapters available for both in multiple sizes. I have several.
- The 1� boring bar is drilled with a �� diameter hole in the business end that is used to receive a wide array of hollowing bit holders. The bit holders supplied with my Kobra includes a wonderful feature: each has a square hole used to receive square tool bits directly without having to round one end. This is a huge benefit!
- The boring bars they supply are solid and are hardened on the exterior and dead soft on the inside. This reduces vibration without making them brittle.
- There is an optional laser that is mounted to a square tube to ensure the laser is positioned absolutely vertically (no false readings as you can get with round ones!). There is a solid aluminum vertical rod that supports the square tube and laser. There is a very nice single flat thumbscrew system used loosen/tighten when changing the position of the laser. Granted the laser provided is the pen type, but it is easily replaced with a heavier duty industrial type of laser. There is a 0.46� dia. hole with a set screw- not an insurmountable problem to change out the laser.
- A banjo-mounted tool rest is included that is supported at both ends. It can be adjusted vertically and is extremely rigid.
The only potential problem I can foresee at this time is going to be their ability to meet the upcoming demand for orders.
Sincerely,
Don Geiger
Web addresses: www.dongeiger.com and www.geigerssolutions.com
Cyril Griesbach
>Well said, Don, but I believe the Green (Junior) Kobra is adjustable for lathes from 10" to 14" swing. I had a friend try my red Kobra yesterday and I'm sure he's going to order one. He said it was far smoother and had far greater movement than his captured D bar system.
Don Geiger
Don Geiger
>They have made a riser system for my Green Kobra to work on my Stubby. They have also supplied adapters for the Red Kobra for 3/4", 1/2" and 3/8" boring bars and for the Green Kobra; 1/2" and 3/8".
I am really enthused about this system. Three other friends of mine have bought them. One has received it and likes it a lot. The other two will be delivered in the next week or so.
Don
