My Cone Jig For Finishing Hollow Form Bottoms
Steve Russell
>Hello to the group,
Last night at the chat, we were discussing jigs to finish the bottom of a hollow form. I mentioned that I had one made from scrap Corian and and old photocopier rod. Ellis asked me if I would post the photo (sorry I don't have a drawing package) in case anyone here at WC wanted to make one up.
Specs: I call this a "Treat" rod, it is known under many other names as well, but since I'm from Texas, I call it by its Texanese name... :-)
The main rod is 18" long and is tapped in the end and threaded. It features a grub screw to secure a sanding mop, or high density pad. The cone is turned from Corian scraps and is also treaded for a grub screw. The photo does not show it too well, but there is a solid metal bar inlaid into the side where the grub screw is to provide a harder wearing surface. The end of the rod fits into a Jacob's chuck.
The Corian cone is adjustable up and down the length of the rod to accommodate different height hollow forms... I have been using this to finish many of my hollow forms for eleven or twelve years. It runs true and works very well indeed. Give it a try and see for yourself how easy you can finish the bottom of a hollow form. Take care and all the best to you and yours!
Steve Russell
The Woodlands, Texas
Re: My Cone Jig For Finishing Hollow Form Bottoms
Close up of Corian cone
Steve Russell
>Hello to the group,
Here is a close up (yes, I'm lousy with a camera and Photoshop does NOT like me...) of the Corian cone showing the grub screw base area.
Steve Russell
Close up of Sanding Mop end
Steve Russell
>Hello to the group,
Here is a close up of the end of the jig, where you mount a sanding mop, or high density "press" pad. The end is threaded as well, allowing you to use accessories that you might want to screw in, in lieu of using the slip fit/grub screw to secure the insert.
Steve Russell
Re: Close up of Sanding Mop end
>Thanks Steve. Between your photos and the website I downloaded last night I will probably build one very shortly.
Roger in MO
Roger in MO
>Steve, would you explain further how you use this? Is the chuck driven by the head stock? Where is the HF placed? What is the purpose of the mop? I guess I've a mental block but I can't seem to visualize it. Thanks. Roger
Steve Russell
>Hello John,
Glad to help... Take care and all the best to you and yours!
Steve Russell
Steve Russell
>Hello Roger,
Please accept my apologies for any confusion... The Jacob's chuck is mounted in the lathe headstock and the "Treat" rod is mounted in the Jacob's chuck. The hollow form is then mounted onto the treat rod and the Corian cone is moved up to the neck opening of the hollow form, but it is not yet secured. The tailstock is moved up next and reset into the original centre point used when roughing/finishing the hollow form.
The sanding mop adds an extra measure of stability to the fixing and can also be used to sand any little bit of nub that may be left in the centre bottom. Once the hollow form is secured with the tailstock, the Corian cone is secured with a snug fit into the hollow form opening.
At this point the Corian cone is set and secured, the sanding mop is in place in the bottom (use of the mop is optional by the way, it is not necessary to use the mop, as the treat rod works equally well with only the tailstock and the Corian cone in place.) and the tailstock is secured. You can now turn the bottom of the hollow form and complete it, save the tiny nub 1/8" or so that you leave where the tailstock point is set.
Once you have completed the bottom, you can pull it off the treat rod and manually carve away the nub and blend the surface with a 1" sanding mop. I hope this helps. If you have any questions, please do not hesitate to contact me. Take care and best wishes to you and yours!
Steve Russell
P.S. Apologies for the photos... That's one reason why I don't post them very often. :-( I think there are gremlins or tommy knockers in my camera, computer and my Photoshop CS3 program. :-(
Allen Neighbors
>Steve, that's a really nice one, especially with the threaded end to take different accessories.
Mine is just a little different, in that my cone has a tenon that mounts in my chuck, and the rod slides into the headstock through-hole.
I can't figure out why some of the pictures (not just yours) are smaller after you click on the thumbnail.
Thanks for posting these! :)
Juergen
>John, If you have a Oneway live center use the large cone (3/4-10 thread) with some all-thread rod of the same pitch. This saves the hassle of having to turn the cone. Cut or file one end of the rod to fit whatever size Jacobs chuck you have, which is then mounted in the headstock via a morse taper. The other end of the all-tread rod is drilled with a 1/4" hole and an appropriate grub screw to fix a 2" velcro sanding pad (with sandpaper for added friction). The whole thing can be made with hand tools available in most home shops.
Carole Valentine
>I have one of these jigs that was given to me (with a wooden cone) and have never seen a need for it. When I reverse a hollow form, I just slip it over a wooden cone (many times just quickly turned from the wood left in the chuck after parting off the form), bring up the TS with a little cup center and small piece of leather as padding and turn away. Works for me, even on very thin necked pieces. I guess ignorance is bliss but I am into simple and fast! :)
Kirsten Cone
Pete Kekel - Kentucky
>The version of this that I have seen (and use) is called a Kirsten Cone. Instead of the Jacobs chuck, it uses a rod with the appropiate Morse taper to fit the head stock. Behind the cone there is a drill stop collar to allow for size changes. Kim Blatt wrote an article and pdf on manufacturing one of these. He suggests making several sizes, so that the cone fits close to the size of the hollow form you're working on.
Re: Kirsten Cone  *LINK*
Stuart Johnson
Kirsten Cone - pdf
Re: I bought one of these thru Joe .....
Jamie Donaldson
>...Moran on the Stubbygroup site years ago and have yet to use it.
Roger in MO
Roger in MO
>Thanks Steve. The lignt finally came on! Roger
Craft Supplies version
Bob Elliott
>It has a 3/4" diameter shaft, 16" long including the morse taper with 1/4" hole on the tailstock end and 3" face plate, you turn the cone.
