motor pulley advice needed
Steven Kubien
>Evening everybody,
I've got a Nova 1624-44 and the pulley which attaches to the motor keeps slipping. This causes excessive vibration as the belt gets twisted and an excruciating noise once the pulley makes contact with the headstock casing. I have tightened the set-screw on the pulley within a centimetre (ok, inch) of it's life but no love yet. I was thinking about Loctite but have always viewed that (Loctite) as permanent and non-reversible. My concern is that the pulley will continue to slip and I won't be able to move that screw.
I have a message into Teknatool and haven't heard back from them yet. Anyone got a suggestion(s)?
Thanks,
Steve Kubien
Ajax, Ontario
Re: motor pulley advice needed
RevDoug
>Lok-Tite makes a medium, un-doable formula. That should do the trick for you. I'll be interested to see what Teknatool says about it.
Turn 'em round,
RevDoug
>I believe it is blue instead of the permanent red.
Turn 'em round,
JohnKJordan in East TN
>Why is it slipping? Assuming the shaft is not keyed, seems it should at least have a machined flat for the set screw to bear against. If the set screw loosened once allowing the pulley to rotate, the set screw may no longer be aligned with the flat and no amount of tightening will prevent further slip. Is there room to slide the pulley far enough to inspect the shaft? (The spindle may need to be removed.) If there IS no flat, you might make one.
Regardless, I think I'd contact the maker. They may have a fix for a known design problem.
>Steve I had the same problem. Other than checking it once a week or so I think Loctite would work. The non permanent stuff is what I would use and I don't remember which color it is. If it you do have trouble removing it heat will loosen it.
I don't own that lathe anymore but if there is enough room can you put another setscrew on top of the first one. It's probably metric but shouldn't be too hard to find. If my memory is correct the isn't enough room to do this but it's a thought.
Steven Kubien
>Hi John,
I should have mentioned that. yes, the motor shaft is keyed. No, the pulley has not rotated. I think after the screw came loose the first time (and eventually rattled totally out of the threads and rolled around in the headstock) I just haven't been able to tighten it down enough. We'll see what Teknatool says.
Thanks,
Steve Kubien
Steven Kubien
>Nice to see this early in the morning John. Could you pass the butter?
Good idea. I can probably get a pair of shorter screws and jam them (the original is too long). I'll look into it.
Thanks,
Steve Kubien
Steven Kubien
>Thanks Doug. I didn't know there were different types of Loctite. I will look into it, pending what Teknatool has to say.
Steve Kubien
Steven Antonucci
I had the same issue on my Nova 3000
steve antonucci
>I used Loctite (blue) on the pulley set screw, and let it dry, then backed the screw out. There are no permanent consequences. Make sure that you have a nice flat spot on the key (vs. the old marks) when you do it and that the key is not otherwise deformed.
Steven
In that case, if if still slips with the locktite and/or double set screws (unlikely!), adding a thrust bearing to the shaft would help to keep the pulley aligned and at minimum, keep it from contacting the headstock casing.
Why you shouldn't just keep tightening the screw
wilbur
>My lathe is an old Walker-Turner from the 1940's, and in the process of restoring it I completely disassembled the headstock. That was a great learning experience.
One thing to be careful of is that if you tighten the screw down too much, you may put a score mark into the shaft itself. This actually will decrease the holding power of the screw, since it won't be sitting on a even surface on the shaft anymore.
It would be much better to see if there are any other reasons why the set screw isn't holding. A common one is that the bottom of the set screw isn't completely flat, so that when it butts up against the shaft, only part of the bottom contacts the shaft.
Making sure that the pulley is in alignment with a flat on the shaft is also important, although not all shaft/pulley setups rely on having a flat.
Other than this, how do you like your lathe? I've made less than 5 bowls now, and I'm already thinking about getting a lathe with more swing.
Jorge Castaneda~Downeast Maine
>Steve,
I have the same problem with my Nova 3000.
First, align the very best you can, in my lathe the pulley must be almost touching the casing.
Then I substituted the set screw that came with it, about 5/8" long, with 2 set screw 3/8" long and tighten them very well.
The other thing to do is to leave the belt rather loose and tighten the the big nut of the tensioner, so it cannot get tighter by itself. Keep an eye on your belt tension before starting each session...
Happy wood shaving!
Jorge
The head rotates...
>Wilbur, I have made bowls a little bigger than the 16" just rotating the head. Now I am making an outboard tool rest, I am too cheap to buy the one they offer for my Nova.
Jorge
Pete Kekel - Kentucky
>Looks like everyone who has owned one of these has had the same problem. I changed out the set screw - the one that came with it originally had a single contact point - to one that had a flatter surface with more teeth for better hold. I think I also wrapped some of the plumber's tape around the set screw and then tightened the heck out of it. Never came loose again.
>I had a similar problem with my motor pulley on my Contractors TS. It would vibrate loose and throw away the key once in a while. Not knowing any better, I removed the set screw, installed the key, lined everything up, poured blue loctite into the set screw hole (A few drops) until it ran out of the pulley around the shaft and reinstalled the set screw. Let it dry over night and it never gave me another problem. My theory was that the Locktite took up the slack aroudn the shaft and key. (I'm sticking with that theory.) Years later it came apart easily when I replaced the pulleys and belt with better ones.
Re: The head rotates...
>I think home built is better. The one they sell is crap. I ended up putting long threaded rod to go from the tool rest to the floor to stop all the vibration. I still had instances when I had to remove the bowl, move the tool rest and put the bowl back on because there wasn't enough movement on the Nova extension.
I think something along the line of the Vicmarc outboard attachment would be much better.
Dennis Yoder
>Don't forget that there are set screws that have a nylon insert in the threads that help prevent loosening. I have seen them in the borgs and I'm sure a well stocked local hardware store would have them. Dennis Y
Re: Why you shouldn't just keep tightening the scr
Steven Kubien
>Other than this, I love my lathe. Speed changes are easy. Enough power for me. The rotating headstock is nice. The tool rest/banjo arrangement is fantastic (locks solid with minimal effort and easy to adjust). Likewise, the tailstock locks good and solid and is light enough that removing it and setting it aside is not left to sumo wrestlers. The only issue with aligning the headstock and tailstock occurs after rotating the head. It is a simple matter to re-align them (30 seconds). do not rely on the indexed stops.
HTH
Steve Kubien
That is reassuring
Steven Kubien
>Thanks for this Barry. Sounds like I can confidently go the blue-loctite route and reverse it if needed.
Cheers,
Steve Kubien
Re: I had the same issue on my Nova 3000
Steven Kubien
>Hey Steve,
Let me be sure I understand what you saying. In order to realign the keystock, I will have to remove the motor and pully. Right? I am also unsure what you mean, or why you would, back of the set screw after applying the Loctite. Granted, I haven't read the instrcutions on the bottle (don't have any yet) but is the backing-off standard procedure?
Thanks,
Steve Kubien
Steven Kubien
>Thanks for the idea about plumbers tape.
Cheers,
Steve
>Thanks John
Inquiring mind wants to know... fortunenelly this wed. weather permiting is our Maine turners meeting and the lathe is a Oneway so i can look and ask questions, several members have the Oneway.
What I am doing is using galvanized pipes, not solved yet how to move it around...
Steven Antonucci
You want to lock the screw on the threads...
steve antonucci
>I mean to take both pulleys off the motor and spindle shaft, and apply loctite to the threads and set screws off the lathe. When it dries, some loctite will be in the thread and it keeps the screw from working loose. If you apply loctite while the pulley is on the lathe, or even worse, on the motor shaft or spindle, it's nearly impossible to disassemble the lathe (experience is that thing you get right after you need it :-)
Steven
>Steve I just looked it up. You need either Loctite 222MS Low strenght purple, or 242 medium strenght removeable Blue.
Carole Valentine
>It's been my experience that 242 won't stick honey to a bee's butt. There's certainly no problem unscrewing anything you use it on. I thought it might keep the lock levers on my Nova from unscrewing. Might as well have put water on the threads. In fact, water probably would have worked better since it would have corroded them a bit! LOL
