REAL MILK PAINT
Lathe Lighting....
Lathe Lighting....
Lathe Lighting....
Wally Dickerman in Arizona
>I plan to use 2 Moffatt lights on my new Oneway lathe which will be here soon. I will do a lot of turning on the outboard side so I want a light on the inboard side and one for the outboard side. I haven't figured out yet how to mount the lights. Any suggestions?
Wally
Re: Lathe Lighting....
>Wally I had several of the quick release bases that I bought from Gary Sanders. I mounted those in several places on My Nova Comet lathe stand. I'll bet you could make a curved piece of wood that would fit over the headstock. Mount the quick releases on that and install some rare earth magnets on the bottom. Then the lights could be swung either inboard or outboard.
Gary in Zirconia,NC
>Wally, Here's what I did. I used half inch pipe. 2 floor flanges, 3 - 12inch nipples, 3 - 2inch nipples, 4 elbows, and a coupler. I can move it to either inboard or outboard.
Gary in Zirconia,NC
>Here is a shot of it over the inboard. It works equally well over the outboard.
Bill Grumbine has a nifty setup
Eddie Pacheco; San Jose, Ca.
>Along with a dentist's lamp, Bill G. has an overhead dual lamp setup that seems to work well and looks easy to implement. It's on my lathe space improvements list. here's a link to a photo and I think he has some plans or better pics somewhere.
http://www.enter.net/~ultradad/roughbowl05.jpg
Mike Brazeau
>Wally - I got this idea from someone who posted here or at WoW. Just take a piece of 2x4 and drill appropriately sized holes. One or more to mount over the swing arm post and some for the lamp in various positions, so you can move it where best suits the task at hand. I think you ordered a rather short bed so the 2x4 should be able to cover both aspects. I just use one of the old fashioned drafting table lamps with a showcase bulb in it. I turned a sleeve to fit into the hole for the lamp. Can't remember why. I think I had it mounted in the swing arm post first. In the lower right is my $300 table mounted on the outboard bed. I need to rearrange things and start using the outboard. It really is a lot easier on the back. There were some pics in a recent American Woodturner of storage ideas here too. I am going to drill some holes to hold gouges one day.
Bill Grumbine (Kutztown PA)
>Wally, just to add a little to what Eddie wrote and the picture he linked to my shop, the Moffat lights are mounted on a "flying saucer" disc which is suspended on a large L of black pipe, and the whole affair pivots around. In fact, it is hanging over the Robust now, and has enough range that I can light up anywhere I want along almost 60" of bed ways. If you want some more details, I can get some specific pictures.
Bill
>I bought an inexpensive set of track lights that I mounted on the ceiling above the lathe. I put in a set of Par 30 compact fluorescent lights. I've adjusted the lights so I get very decent illumination on the lathe and my work piece.
Moffett's rule!
Peter Teubel
>I have a dozen Moffett lights all over my shop (4 dedicated to my big lathe). The arrows point to extra mounting posts for the lights. I can either move the existing lights or add more as needed. The articulating arm is from Gary Sanders (who sold the manufacturing rights to Oneway). It was originally designed to attach to the back side of the lathe, but the dust hood prevented it from reaching the outboard side. So I simply attached it to the front. The hood makes an excellent platform for the other lights. I also have a lamp mounting point on the tailstock.
Re: Gary, thanks for posting...
Allen Neighbors
>these shots of your light. I've gotten some good ideas from them to revamp mine. Much appreciated. :)
Richard Allen
Richard Allen
>You can't beat the light stand now sold by Oneway. The whole thing holds two lights, can swing to either side of the tailstock, is designed to mount on the oneway rail and has an electrical outlet for power sanding or whatever.
Better is the dust hood which can eliminate airborne dust while sanding at the lathe. The stud mounts for the moffit lights work great mounted to the dust hood. The dust hood rides on a rail which lets you move the hood from the inboard side to the outboard side (for use on either side of to get the hood out of your way is necessary, you can spin a 24" piece of wood with the hood in place).
Chuck Engstrom
>Moffatt lights mount on a 1/2" stud with a little groove in it which serves little purpose but to keep the lamp from flying up into the air when your neighborhood has a gravity outage. You can make them yourself without much trouble -- see page 3 of http://www.moffattproducts.com/pdf/TaskLightingDesignGuide.pdf for ideas. I mounted an MS2 base on the far end of my banjo, but I could have saved a bunch of bucks just buying a 1/2" bolt with some straight shoulder, cutting off the head, and tapping it in.
I share this because Moffatt will NOT sell their various little mounts to individuals. If you call Moffatt, they'll make you call someone like MSC, who sell Moffatt products but don't list them under that name and will burn up a bunch of your time figuring out what you're trying to buy. Then they have to call Moffatt to get a price, and then calculate shipping etc, and when that's all done, guess what? -- the item is dropped shipped from the Moffatt plant.
Buying a Moffatt adapter should be a three-minute phone call to Moffatt. It took me most of an hour for several calls back and forth with Moffatt and MSC. The lamp itself is certainly a fine product but their attitude toward end-users is poor, and I just can't resist this opportunity to reciprocate.
Chuck Engstrom
Steven Kubien
>This is funny. Just today as I attempted my first hollow form, I thought of you, Wally. The thought quickly turned into, "Gee, I wonder if Mr. Dickerman got his new lathe yet?"
Have you developed a twitch or anything in anticipation?
Kindest regards,
Steve Kubien
>No Steve, no twitches or nervous tics. Actually I've been too busy with other things..travel etc. My Nichols has been moved into the garage so I have turned my last piece on it. It has served me well for 11 years.
Wally
Fog Tanner
>Chuck,
Thanks for the idea on the 1/2" bolt. I need another base for my Moffet so I can move it around. Now that Gary has quit selling the lights I pretty much gave up on getting another base, but I will going by a hardware store tomorrow and take a look at their 1/2" bolt selection..where I live there are laws against gravitational outages so I guess that groove is of no use here, but I can always add a safety strap to be on the safe side. Never know when that buch of fools in Austin might sign a bill removing gravitational restrictions during a hurricane evac, they have done more ignorant things :-) ...
Fog
Re: Yep, Chuck,...
Allen Neighbors
>They are awesome lights, but I think Moffet is about as bad as Microsoft and Vista. :)
I think I'm going to go Gary's route...
Re: Yep, Chuck,...
Fog Tanner
>The only thing worse than having a machine trying to run Micro$oft and Vista, is two machines trying to run Microbrains and Vista....and anybody in dataprocessing has at least two machines (I have 6-8 and over a dozen operating systems)..but sadly I will have to move to Vista when there are no operating systems left.
That is a nice setup, if I had lower ceilings I would probably go that route. But mine are between 9 and 10 feet over the lathe. I do have a track light mounted on the rafters with a 75 watt halogen spot. It is aimed just in front of the spindle and does a great job of lighting up the piece. Caught a close out sale at one of the box stores and got some great deals.
Chuck Engstrom
>Hey Fog --
You'll need the groove, of course, if you're going to mount the lamp hanging downward from the base. I expect it would be pretty quick business to mill a groove by putting your bolt cut-off in a drill press or lathe-mounted chuck or collet and attacking with a small chainsaw file. The Moffatt stud does measure a true 0.500" so you might want to check the actual size of bolt shafts.
I don't have your depth of experience with operating systems but I do know that my new Vista computer with 1G RAM and dual-core is slower than my WinME Celeron with 192 megs RAM. I am still finding new XP machines for my clients.
Best--
Chuck
Tim Grenville-Cleave
>I run XP, Vista and the Ubuntu dist of Linux. I use Linux first if possible if not then XP and Vista only as a last resort!! Oh and just to show I am not biased I run a Mac as a hobby!!
George Van
>Your question is very timely Wally, I have been fighting for a year trying to find the �perfect� lighting system for my Oneway, the Moffatt light does not clamp to the round headstock. I tried a box with a metal plate but found that got in the way of tool/body control so I took it off. I too will try to use some of these ideas to finally get it right. One thing I did want to try was to hang a shelf from the 11� ceiling with a steel plate on the bottom for magnetized bases and several electrical outlets. This could possibly be used as a base for the vacuum duct work also so it can be overhead and not clutter the floor or work space around the lathe. Good luck organizing around your new lathe!
Belly light...
JohnKJordan in East TN
>>...ouitboard, inboard
In thinking about lathe light, I decided a Chest or Belly Light would be very useful! A conventional light between me and the work is always in the way. My head shadows overhead lights as I move around. Side lights behind only remind me of the need to diet. A Belly Light, e.g., built into a fanny pack worn in the front, might light that part of the work that is always in shadow. You patent these and sell them and send me half the money. :)
I also want a bright light mounted inside the hole in the tail stock. This would let me look inside the hollow as soon as I remove my tool without having to reach and turn on my little flashlight.
But for your question, I attach an articulated light with a magnetic base to the cast iron ways at the far side of my lathe. It can be easily moved and positioned. I usually like it down low for the glancing light needed to properly inspect surfaces. The only problem is an open reflector tilted upwards catches chips - it needs a clear cover on the front.
>>...when your neighborhood has a gravity outage
I laughed out loud at this! With this new threat, I'll have to go out and tie down all my goats and go shopping for a gravity generator for the house.
The following lighting method may not apply exactly to the topic, but if someone else caries a mini lathe around at times they might be interested: Several times I've set up a Jet mini on a sidewalk at night for demos. I could not rely on having enough ambient light or somewhere to clip a light.
I use a length of threaded rod in place of one of the corner bolts holding the lathe to the stand, slide a piece of steel tubing over that, then slip the base stud of one of those cheap Walmart swing-arm lamps into the top of the tube. The steel tubing is long enough that the articulated arm clears the lathe for all possible positions, and lamp is high and out of the way. I think this worked better than carrying a lamp on a floor stand.
Gary, did you experiment with...
Clem Wixted
>...adding another section to allow up and down adjustment? Or, does the flex piece on the light give enough range?
I'm thinking that one more section could be added to allow an up and down movement of the light. It might be tricky to get the right tension on the elbows to keep the light in the selected position.
Curious if you have already done the testing.
Clem
Richard Bentley
>Although fluorescent lighting isn't recommend. I put up a fluorescent fixture with reflective background and used T5 bulbs works great you practically need sunglasses..
Re: Gary, did you experiment with...
Gary in Zirconia,NC
>No, I haven't tried up and down adjustment. I think getting the friction right would be difficult. I put mine at a height that allows the light to be around head height most of the time. My light is a 24". The weight of the lamp makes it more difficult to put it high than lower. If you go this route, experiment first by holding the lamp base at different heights and moving the head to find where it works best for you. I think the 18" would work better for the upside down position. The head might stay in the up position better.
