Downed trees
Downed trees
Downed trees
>I can easily get a lot of wood from areas where there has been wind damage. There are two problems. The root ball is still on there which of course is quite dangerous, and then you have to figure out where the weight is going to shift so you don't pinch the saw. That's what this question is about. Has anyone tried to use a hydraulic jack or something similar to support the tree so it won't pinch the saw. I'm pretty good at guessing the pinch direction 80 or 90 percent of the time. It's that last 10% that drive me crazy. This last fall I spent about an hour with an axe and wedges trying to get my saw out. I will often use some dogwood wedges to block the cut open but this doesn't always work.
Re: Downed trees
Re: Downed trees
MWWoodWorks
>If you are often getting your saw stuck, you are A) comeing at it from the wrong angle and / or B) cutting too agressivly. When cutting a downed tree like that the weight shifts often so you have to be very careful and take your time. Cut just a little bit and watch it very closely to see what effect your cut is having on the tree. The weight distribution changes often as the tree gets closer to the ground. For example, it may be getting caught in other trees, or the trees branches on the ground may cause the tree to start twisting to one side or the other. You have to be able to read these signs closely. Without the proper experience, you will almost always get your saw stuck. :) The least experience you have the slower you should go with it. Make a small cut and observe. On the other hand, it is very hard to not go hog wild with cutting chains attached to motors! LOL Secondary advise, get another chain saw to cut your stuck chain saw out! LOL Just don't get them both stuck, thats embarrassisng! LOL Good luck!
Re: Downed trees
Re: Downed trees
Cyril Griesbach
>John, I take two saws. No need to ask me why. And, I do go slow when there is the chance of unpredictable movement.
Re: Downed trees
Re: Downed trees
Carole Valentine
>Wouldn't it be a lot cheaper just to carry a spare bar and chain? If the bar gets stuck, take the saw off the bar and put on the spare.
Re: Downed trees
Suggestions....
Peter Teubel
>Wood wedges don't cut it (no pun intended). Long (10"+) plastic wedges help keep cuts open. They also have barbs on them that help keep them from shifting. Of course, they are not a cure-all. That's why I have more than one saw...to cut out a stuck one if necessary. If you only have one saw and get it stuck, you can unbolt the bar, slap on another one, and cut the original one out (carefully).
Re: Downed trees
Re: Downed trees
JohnKJordan in East TN
>John,
Could the dogwood wedges have been too "fat"? The slimmer the wedge, the more sideways force you can apply with a given hammer blow. I haven't pinched a saw chain since I started driving in several plastic wedges above the bar just as soon as the kerf was deep enough. Some were pretty big trees. I use the brightly colored wedges available at the chainsaw dealer - they come in two sizes.
Also, I think you need to use the wedges before the chain gets pinched. The wedges keep the log from dropping while you finish the cut - once it begins to drop I found it very difficult open the kerf with wedges since no amount of wedging can lift the tree again, but only push outwards against the weight (and worse, against the remining uncut part of the trunk!)
We have jacked up trees with a timber underneath then use the to jack lever the timber. You need a pretty strong timber for a big tree. A steel i-beam is better but it's pretty heavy to carry into the woods.
BTW, the best advice I read once is to take a spare bar and chain into the woods. Handy in case your bar or chain gets damaged, but EXTREMELY handy if you get the chain pinched - unbolt the head from the pinched bar and use the spare to cut it free.
Re: Downed trees
Re: Downed trees
Gary Evans Tallassee, TN
>Hi John,
I've always liked John K's suggestion. Just carry an extra bar and chain. That way if you get stuck, you're just two nuts away from freedom. Also, having an easy way to get free will probably keep you from ever getting stuck again. 8^]
I also agree with the go slow till you see which way the kerf is going to move. You can usually see movement at the kerf before it gets to the point of stickage, particularly on the big stuff.
As far as cutting trees with a rootball on, I like to start at the top and work my way toward the rootball. I have left wood on the ground rather than work too close to a rootball that I wasn't comfortable with. I have used tractors as well as come-alongs to secure the rootball in place so it couldn't come after me. I've also blocked up under the bottom of the stump to keep one in place.
Gary
Re: Downed trees
Re: Downed trees
>Wow, I can't believe how many people posted to this thread while I was typing - when I started typing there were no replies!
BTW, I'm sitting here at the computer since it's 15 deg in East TN this morning - I'm putting off going down to the barn to wrestle with the frozen watering troughs as long as my conscience will let me!
Re: Downed trees
Dick Hines
Re: Downed trees
Dick Hines
>John, just remember, do not stand with the tree between your legs. You could be in for a ride if you do.
I cut one after a storm and the thing stood up like nothing ever happened. It made me very rethink how I was going to cut up all those downed trees.
Re: Downed trees
That's what I do.
Brian Hahn in SW Wisconsin
>Two chain saws and wedges.
It also helps to have a tractor with a bucket and several logging chains. My tractor is a compact utility tractor, so I can usually maneuver it into position in the woods. Of course, the woods has occasionally "customized" the tractor.
Re: Downed trees
Re: Downed trees
MWWoodWorks
>I just found out that I did some work for you in fact Mr. Hines. Years ago I met you (I think) Over in Diascund?
Re: Downed trees
Re: Downed trees
MWWoodWorks
>See, that just absolutley KILLS the chance to justify buying a bigger chainsaw! No fair!!! He He
Re: Downed trees
Steven Antonucci
In addition, I'll make relief cuts
steve antonucci
>Similar to a felling notch. Keeps things from getting pinched.
Steve
Re: Downed trees
Re: Downed trees *LINK*
Bill Grumbine (Kutztown PA)
>John, I use two saws, wedges, extra people, and a truck when possible. If you have the time, check out the link below from an article I have on my old personal website.
Bill
Harvesting a BIG Tree
Re: Downed trees
ebd
Re: Downed trees
ebd
>I don't get stuck very often but when I have I've used hydraulic & scissor jacks, pulley hoists, a peavey, and a come along. All work, though with the hoists and come along you've got to have something to hook to.
Re: Downed trees
Dick Hines
Re: Downed trees
Dick Hines
>What type of work and how long ago?
Re: Downed trees
Re: Downed trees
MWWoodWorks
>Treework, it was probably 3-4 years ago at least. I think it was you anyways. You were turning a bowl that you had cut slots all around the rim of and had inlayed copper. You had the most awesome Bonsai trees too. You live in Diascund? I was the skinny guy working for the tree service out of Providence Forge. You may not remember me and heck you may not even be the same guy! LOL You had a bunch of turning wood staked behind your shop and your chainsaw setup on a little ripping bench you had made out front? I hope it is you that I am thinking of otherwise this is going to be very embarrassing! HA
Re: Downed trees
You scare me!
Mike Jones, Redding, CA
>John, Someone that asks a question like yours scares me. It is like someone that asks what kind of climbing rope/SCUBA gear/life jacket do I need. Please be careful! Take someone along, cell phone on your hip, chaps and hardhat, steel-toe boots, eye protection, etc.
Work the small end and limbs off first if you can (reducing weight and stresses), take bucking wedges and a heavy beater to drive them.
Leave your jack at home. If you have it with you, you'll be tempted to use it, and a situation that might call for the use of a jack is a dangerous situation. Generally, you should not be doing anything under the weight of the tree.
To prevent pinches, insert a wedge as soon as the bottom of the wedge will clear the top of the bar and chain. Now take little bites, a few seconds with the saw, then stop and drive the wedge... and repeat.
Abandon a cut and start a new one along the bole if there is the slightest pinching that the wedge will not relieve. Stay focused...
Mike
Re: Downed trees
Re: Downed trees
Clay Foster
>John,
Mike Jones has given the same advice I have: use your brains, not the brawn of a jack. A jack will just introduce more tension and pressure into a situation that already has enough.
Start at the branches and work your way to the root. Before you make a cut, ask "what will this limb do when I cut it off the trunk, and what will the trunk do when I cut this limb off."
Further advice from Pingwortuk, an Inuit who lives north of the Arctic circle:"The secret for staying alive is to always keep yourself in the position where you will be able to take advantage of that which is about to happen."
Re: Downed trees
Re:That's good Clay! When we were.....
Jamie Donaldson
>...making plans for Ranger missions in Vietnam the rule was "always know the way out before going in!"
Re: Downed trees
Dick Hines
Re: Downed trees
Dick Hines
>You must have been working for Wray Tree Service. After the storm I keep them busy for a while. I still have a pile of turning wood behind the shop. Are you a turner? if so you need to join the Richmond Woodturners if you are still in the area.
Re: Downed trees
Steven Antonucci
Trees don't fall the wrong way-but you can be
steve antonucci
>standing in the wrong spot!
Steve
Who has had a few trees fall somewhere other than where I had planned and lived to tell the tale...
Re: Downed trees
Re: You scare me!
>Mike I've cut a lot of downed trees and like I said I hit it right about 90 percent of the time. My thoughts were if you could jack the tree up a little then you know it would fall down instead of pinching the saw. This would not only save you that agravation but would be a whole lot safer.
I usually start by trimming the limps away as much as possible. this reduces the twisting and shifting of the log but sometimes you just can't cut off those bottom limbs that apply upward pressure. If I read it correctly I cut from the bottom and it clears with no problem.
Re: Downed trees
Re: Downed trees
>Carol That's what I've learned to do. I like the idea of carrying two saws. Never pass up a chance to buy a new tool. :)
Re: Downed trees
Re: Downed trees
>Yea I was blown away. I've been working all day away from any computers. This is why I asked this question because I know others had probably experienced this problem so I wanted to hear the solutions and thought others would enjoy this.
