Inlay--Need your expertise
Joanne in Point Pleasant, PA
>No, don't get excited--your favorite lurker did not get a lathe in her shop yet. I am building a table and there is a knot in one of the boards that is the top. I don't have enough cherry of the right grain and length to replace the whole piece, so I thought it would be fun to dig out the soft wood and fill the knot with some filler and on the very top layer, use turquoise of some other crushed stone of a bright color. I know many of you have used such inlay in turnings. What is the best way to attach the stone? Epoxy? Do you just sprinkle the stone in the hollow and fill with epoxy? Thanks in advance for your help.
Re: Inlay--Need your expertise
Cyril Griesbach
>Joanne, consider using Inlace..available from Craft supplies and other sources. There are a variety of color selections and it is available with the color mixed in the matrix to which you add the hardner or it's available as a sort of powder that you add to epoxy. Any voids that occur after you have sanded it level with your surface can be filled with gap filling CA glue.
Re: Inlay--Need your expertise  *LINK*
Ron in Drums PA
Router bit inlay set
Jennifer@Indy.USA
>I think Joanne is wanting to leave the knot as is and not route it out? Correct me if I'm wrong Joanne? I've used the Inlace before but is seemed like you could get the same results from epoxy and your own crushed stone? I'm not sure if it is the same as epoxy or not? It sure would be cheeper. It did smell the same as epoxy.
Jen
Darryl
>The least expensive (that I have found) place for "Inlace" is
tutlefeathers.com
They are very helpful. It come in several colors as well as clear.
Jen's right
>Thanks, Ron, but Jen's right--I want to leave the knot irregular shape as is and fill it. But thanks for the reminder of the inlay set. I thought I had one of those, but can't find it. I want to use that for a different project. The link is helpful.
Anybody do as Jen describes--using crushed stone and epoxy? I have stone I can crush.
Stuart Johnson
>When I use turquoise to fill in cracks in Mesquite I crush the stone, mix it into the resin and then mix in the hardener. Use a small stick to push it down into the crack and leave it up above the surface just a bit. You should be able to flatten it by using a course sandpaper at first to bring it down to surface level. If there are any little pin holes you can fill them with CA.
Re: Jen's right - and I have done it
Carol - now in NC Nebraska
>I filled the spot with the crushed stone and dribbled in thin CA. My reasoning was the thin stuff would have fewer bubbles. Fill it a little proud and then level it. If it's deep, do layers. Wait until it is really dry. To level, use sharp tools you will have to keep resharpening. A job for the cheap chisels. LOL! Sanding just removes too much wood around the inlay.
I have also used the router to level it. Set a straight bit so it just almost kisses the surrounding surface. Then keep kissing the edge of the inlay until it is level. Don't bull through it or you'll rip out more stone than you planned on. Bit won't be worth much when you finish though. But it works.
Long sleeves and FACE PROTECTION, young lady. That stuff smarts!
Re: Jen's right
>Thanks, Ron. That article is a keeper.
That's it, Ron!
Joanne Adler in Pt. Pleasant, PA
>Perfect! Great article. Thank you. I'll let you know how it turns out.
Perfect!
Jennifer@Indy.USA
>Carol, thanks for the ideas of how to sand or flatten the stone, once it's glued down. I would think of sanding and sharp chisels. I am not so sure I'd have thought of the router. I always wear safety glasses in the shop, and in this season, long sleeves, but thanks for the warning. Let you know what method(s) I wind up using.
>I prefer the Inlace crushed plastic that looks like stone. It's so much easier to work with than stone and in smaller sizes looks just as good. The clear Inlace is excellent however it's expensive and you probably don't need that much unless you just want to play with it in other projects. I agree www.turtlefeathers.com is the place to buy it.
If you want to use epoxy check it out carefully. Most epoxy isn't clear. I have had excellent results with System 3 mirror coat. You can get that from Woodcraft but it's pretty expensive. I would suggest getting a casting resin from some place like Micheals or Hobby Lobby. I use Cast-n-craft but you can get other brands and they work well. Casting resins are very clear and release air bubbles better than epoxy. It's also about $10 per can vs $15 to $30 for the system 3 or Inlace.
If it's a small amount of fill it's hard to beat CA glue. The thin is used to glue stone or metal into the crack or knot edges. The medium is better to fill the voids. Don't use accelorator because it can turn the glue white. It takes a long time for it to dry when it's this thick so put it up and be patient.
Thanks, John
>I think I will try the thin CA glue as you and Carol and others have suggested. And no accelerant--which will greatly tax my patience, I'm sure. Especially since I am not known for my patience in the first place. lol!
Ground red shale for cherry
Mike Brazeau
>For cherry I use powdered red shale mixed with epoxy or CA. The color is almost the same as the pitch pockets found in cherry. Got the idea from the earth pigments that LV sell. At the time construction work in the area had unearthed tons of the stuff and I grabbed a few chunks. Works well around knots and bark inclusions.
Re: Inlay
Bill Hale / The Wood Spinner
>Joanne
Depending on the depth of the voids in the wood you do two things. If the voids are deep you can fill the deep areas with fine sawdust you have made black. This realy sets off the color of the stone. Sprinkle the crushed stone on the surface and use a dental pick to push it in. Try not to leave any of the stone proud of the wood surface. Apply a thin coat of CA to lock the stone in position, no accelerator. Apply a second coat of thick CA to top it out and a little proud. Sand and finish
Good turning and be safe
Bill in CG, AZ
