grinder cabinet
grinder cabinet
grinder cabinet
Clay Foster
>While waiting for the drywall mud to dry, I work on things I enjoy, such as this grinder cabinet to go by my lathe. The wood is cedar elm.
Re: grinder cabinet
interior view
Clay Foster
>There are adjustable shelves inside where I can store chucks and other paraphernalia.
Re: grinder cabinet
What about some 'hot' mud?
david
>The chemical set joint compounds come in types that will set in 30 minutes, I think. But then there would not be enough time to pursue some excellent flat work. Great wood selection for the styles and the raised panel.
Re: grinder cabinet
Re: Grinder Cabinet
Donna Banfield
>Holy crap Clay, a cabinet that nice looking would end up in my house, and NOT covered with metal particle dust, wet wood shavings and everything else that goes on in my shop. Nice work!
Re: grinder cabinet
Re: Grinder Cabinet
Bill Neddow
>I agree, Clay. My wife would never allow me to keep a cabinet like that in the shop. It would end up in the living room!
Re: grinder cabinet
Re: Grinder Cabinet
Allen Neighbors
>I also agree. Too nice for a work shop! Exceptionally well done.
Re: grinder cabinet
Re: grinder cabinet
Steve Mushinski
>Clay,
That is just showing off in my book. :) Very nice indeed!
Re: grinder cabinet
Re: grinder cabinet
>Wonderful Clay. I just used cheap wood and painted it gray.
Re: grinder cabinet
Cedar Elm
Mike Nelson
>Don't you love that wood? We have tons of it around here and I use it all the time for bowls etc. Did you cut and dry your own or buy it? It is a stable wood that warps very little while drying.
Re: grinder cabinet
Re: interior view
Doug Thompson near Cleveland
>That is way to nice to use... Good job.
Re: grinder cabinet
Re: Cedar Elm
Clay Foster
>Mike, I do like the way it looks, even though it is as hard as cast iron when it's dry. I did mill and air dry the wood. It is stable, but I quartersaw everything any way. I've got two book matched pieces of cedar elm 9'long and 12" wide that will be the counter top for another cabinet I'm making for the shop out of quartersawn white oak I've had drying for a couple of years.
Re: grinder cabinet
Re: What about some 'hot' mud?
Clay Foster
>Thanks, David. As you've noted, quick set compound would be counterproductive for me.
Re: grinder cabinet
Re: Grinder Cabinet
Clay Foster
>Donna, I'm kind of OCD about cleaning my shop. I sweep and vacuum everything after every bowl.
Re: grinder cabinet
Re: Grinder Cabinet
Clay Foster
>Bill, the living room is already full, although I do want to get rid fo the couch and make a couple of Morris chairs.
Re: grinder cabinet
Re: grinder cabinet
Clay Foster
>Thanks, Steve. When you get wood like that, you have to show it off.
Re: grinder cabinet
Re: grinder cabinet
Clay Foster
>Thanks, John. I can't afford to buy wood and paint, so I just have to cut up trees and dry the wood myself to have materials.
Re: grinder cabinet
Re: grinder cabinet
>I can't afford wood either so most of my shop furniture comes from leftovers from other projects for customers. Consequently paint in necessary. I would love to harvest my own wood but simply don't have a place to store it. I'm working on that but it's going to be a few years down the road. Around here I can get so much good wood for free that it's a shame to have to pass it up. I throw away more wood than I turn because it sits in the driveway and goes bad.
Re: grinder cabinet
Re: Cedar Elm
Mike Nelson
>Clay, I have some I'd like to cut and dry, how did you cut your 9' logs? Do you put weights on top after sticking the green wood? Mike
Re: grinder cabinet
Re: Cedar Elm
Clay Foster
>Mike, I saw it with a chainsaw. I draw a line down the log with a lumber crayon using a string as a guide, and then saw away, bisecting the log through the pith on the first cut. Then I draw more lines and saw again to whatever thickness I want. I usually saw the boards 2 - 2 1/2" thick so I can resaw and bookmatch after it's dry. I dry them outside for a year, and then dry them indoors for another year before using them.
I don't weight them while they dry, other than the weight of the other boards on them.
These two 9' long matching pieces are so heavy I can barely pick them up, so I'm jointing them with a router instead of killing my back trying to push them over my jointer. I'll get them flat enough with the router sled to run them through the planer until they are close to the final thickness. Hopefully by then they will be light enough I can run them over the jointer to get a truly flat surface and then finish planing them. Then I'll joint the edges, glue them up, rip to width, and have a cabinet top.
Re: grinder cabinet
Re: grinder cabinet
charlie belden
>Some people would bleach the dark grain or
stain the light grain trying to get everything
about the same. You used the contrast - and
it must've been fun flippin' and slidin' and
turnin' to get things to work. The result is
REALLY nice!
Only change I'd have made was to go with
a simple bevel raised panel bit to avoid the
shapr shadow line.
I'm betting someone will ask why you went
to all the trouble for "just a grinder cabinet".
The answer - Why Not?
That's the nice thing about doing "shop
furniture" - nothing has to match any of
the other stuff.
Nice work!
charlie belden
