OT: Anybody try this?
david
>On ebay a person will download infomation to you (for ($7.95) on how to repair spent battery units for various mulit-volt battery units. A new battery will run in the $60-$70 range, and I have a couple sitting around that will not take a charge any more. Sounds too good to be true, which is why I am skeptical.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEBTOX:IT&item=250198925187&_trksid=p3984.cTODAY.m238.lVI
Re: OT: Anybody try this?
Brian Hahn in SW Wisconsin
>Repairing battery packs isn't that difficult for someone that is competent with electricity or electronics: take the unit apart, replace the cells, and put it back together again. The tricky part is getting the right size and capacity replacement cells.
I'm lazy. I take the battery pack to a battery store and let them do it. It isn't cheap, but it is the only way to keep tools that use obsolete batteries alive.
p.s.
>There are methods for temporarily rejuvenating dead cells, and that seems to be what he is selling. My experience has been that this is only a temporary fix at best. Cells have a finite life and you are usually time and money ahead to replace all the cells in the pack with new ones.
Having someone else do the re-build also solves the hazardous waste disposal issue for the old battery cells.
Re: OT: Anybody try this? *LINK*
JohnKJordan in East TN
>I have no idea what information they are selling, but I'd hate to pay for it.
Repair methods depend on what is wrong with the battery pack. If a nickle-based battery pack (nicad, nimh) has been well maintained and has simply outlived it's useful life, don't waste time trying to fix it - rebuild or replace. If the battery has the correct voltage when charged but reduced capacity, it may respond to reconditioning. The cadmium crystals in poorly maintained nickle batteries can grow significantly, reducing the efficiency and capacity of the cell. A pack with such capacity loss can often be restored by multiple conditioning cycles, i.e., discharge then recharge, repeat (NEVER discharge completely to zero volts).
A more serious problem can develop if crystals grow large enough to short a cell. These are sometimes called "wiskers". My electronics mentor expert repairs such batteries by zapping them with a significant current. This can vaporize the wiskers and allow the battery to be conditioned used again. He does this by wiring a bank of large electrolytic capacitors in parallel then giving the cell a good jolt. Depending on the extent of the damage, this may or may not work on a particular cell.
If the pack cannot be restored by these methods or if it is outlived it's useful life, it should be rebuilt. Some have screws and will open easily while some need to be cut apart. You can locate and replace the bad cells. Usually just one is shorted. However, it is better to replace all the cells. Be careful not to include a weak cell or it can be reverse-charged and damaged by the others on discharge. (Since it is impossible to have perfectly matched cells, the danger of cell reversal is a big reason not to deep discharge nickle-based batteries until they are completely dead.)
New cells CAN be soldered together, but this is not advised since soldering is difficult and the heat from soldering can damage the cells. Cells are best connected by spot-welding, which unfortunately is best done with special equipment although you can do it with a high current source.
By far, the easiest thing to do is take the battery pack to a battery store and have them rebuild it. (Batteries Plus does that around here.) They have all the cells and equipment and can usually rebuild one while you wait. If it comes apart with screws, take the whole pack. If you have to cut it apart, take the guts.
Another thing - I was looking for replacement batteries for an old Dewalt cordless drill and discovered I could buy a new drill on sale with two battery packs for far less than the cost of the battery packs. Now I have too many drills!
There is much good technical information on the internet. The link below is one of the better resources I've used over the years. Chapters 10 and 5 may be especially useful.
good battery info
Thanks John & Brian!
david
