ADVERTISE HERE - FREE TRIAL
Salvaged a bowl with Hunter #3
Roger in MO
Roger in MO
>I finally put the components of a #3 together and tried it out. One nice tool! This bowl was actually in the burn box when I decided to try the Hunter on it. It is a walnut scab that I had roughed out maybe 2 years ago. It has a couple of side knots, bark inclusion on one side, and several voids. Tell me what you think.
Thanks
Roger
Re: Salvaged a bowl with Hunter #3
Roger in MO
Roger in MO
>Back to the picture posting instructions! Sorry about that.
Roger
Roger in MO
Roger in MO
>Hopefully this time it will post.
Roger
Roger in MO
Profile view
Roger in MO
Roger in MO
Bottom view
Roger in MO
>No finish yet. Roger
I'm Impressed ! ! !
Barry Turner
>Actually, quite impressed. That's a rather large void. If the Hunter #3 allowed you to do that, I am impressed! By the way, I had a Hunter #3 in my Christmas stocking this year. It's still in the clear plastic tube. Now, I can't wait to try it. Tell me more about the Hunter.
Roger in MO
Re: I'm Impressed ! ! !
Roger in MO
>Barry, The extent of my experience with it is finish turning two roughed out bowls, one in cherry. I tried to follow soom of the recommendation that John Lucas has posted over the last month or so. I rotated the tool about 45 degrees so that it was "shear/scraping" The only trouble I had was turning the inside corner between the bottom and side of the bowl. Believe it is a matter of tool position to solve that. I'm sure you will like it.
Roger
Texian
>That is one wild looking piece of walnut. Great save!
Re: What they said.
Allen Neighbors
>I think you're to be commended for this save. What is the diameter of the cutter on the #3?
Roger in MO
Re: What they said.
Roger in MO
>Without measuring,I'd say its close to 3/8" It is mounted on a 7/16 rod that is ground slightly where the cutter sits. (Shop built) I'll try to remember to check tomorrow.
Re: Thanks, Roger.
Allen Neighbors
Re: Thanks, Roger.
Texian
>Allen,
The #3 cutter is 3/8" dia. and the #4 is 1/2". Mike has a couple smaller sizes also. Ck his website.
