Bigtime gloat. . .
Bigtime gloat. . .
Bigtime gloat. . .
Andi Wolfe
>I've been wanting a Sil-Air compressor for several years, but put off buying one because of the expense. However, this was my year to take the plunge and I finally had some time today to get into my shop and give it a try.
I bought the 100-24, 6 gallon tank model. It's the same size as the contractor's compressor I've been using for the past several years. All I had to do to set it up was to add the connector and air intake filters. Pretty easy, all-in-all.
How quiet is it? All I hear when it cycles on is a click as the motors kick on. Sweeeeet! My family is pretty happy about it, too, since my shop is in the basement next to the family room.
Re: Bigtime gloat. . .
robert davis
>congratulations! and to the family also..that is the only compressor to run indoors
robert davis
>CONGRATULATIONS! and to the family..
david
>Congratulations, Andi! Is Sil Aire the only manufacturer you had under consideration? Interested in knowing what else was a candidate for your shop.
Thanks, David
What...
Peter Teubel
>...are you using it for? After looking at the specs, it seems they have extremely low CFM ratings.
Andi Wolfe
>David - I looked at the Val-Air from the same company. It has a little higher dB level for less $$$, but not enough of a savings to tempt me to buy it instead of the Sil-Air.
Re: What...
Andi Wolfe
>The CFM for the model I bought is 4.3. I'm using it to run a Powercrafter carver, which requires 2 CFM. Perfect for my needs, but it won't run die grinders and equipment that need 7 CFM. I don't use those types of equipment in my work at this time. Whenever I have the opportunity to build a real shop I'll hook up a proper air compressor system, but this unit serves my needs in my small basement shop.
eliot d
>I have one of those "ordinary" oil-less, very loud compressors that I use almost exclusively for blowing out the shavings from hollow forms, cleaning the shop, and(at lower pressure) to power my PowerCrafter high speed tool. Of course , I hate the noise. Would what you just purchased work for the first two tasks I mentioned?
Re: What...
Doug Thompson near Cleveland
>Congratulations! I bet your family is thrilled, everyone just loves to hear a compressor run and run and run... LoL They are expensive but will last forever.
Good one Andi
Andi Wolfe
>The compressor will certainly work for the Powercrafter and blowing out shavings. If your shop isn't huge, it will probably do for blowing out the dust and odd bits your broom or vacuum miss. I won't use it for blowing dust because my shop is in an enclosed space - vacuuming works best for getting up the odd bits.
Re: What...
eliot d
>Do you know what they cost? I tried to contact sil-Air to ask them, but I didn't get a response.
Prices *LINK*
Rick Allen
>Hi Eliot
These are the prices I found through the sil-air site.
Silent air compressor price list
