>Santa brought a digital camera early so now I can post some photos.
This is a cherry bowl that I roughed out in April and just completed turning. It hasn't been finished yet--will probably use Min-Wax oil.I was too aggressive with the finish turning and broke out a section of the bark so elected to remove all of it.
>Roger - looks like you did a very good job. The things I look for are the two high sides the same and the two low sides the same. Also I look at the inside to see if the wood grain pattern is located in or very near the center of the bowl. Finally, the wall thickness should be uniform. Everything looks very good, except for the wall thickness. This might be an optical illusion from the picture, but the lower side looks thicker than the high sides. I think we all tend to make the side walls thicker as we go down inside a bowl. The natural edge bowl with the low sides makes this easier to see compared to a traditional bowl with a flat top. Keep up the great work.
>Congratulations on your first NE Roger. It is not unusual to loose the bark if the wood was not cut in the winter or when the wood is spalted. Looks like you got a uniform edge. Save this one for future reference!
>Now that you know what's involved, turn the next one complete from green wood and there will be a better chance of the bark staying on. Not guaranteed tho.
>Thanks for your comments. Jake, you are correct, there is some difference in the wall thickness. I had not figured out why until you pointed out the tendency to make the walls thicker as I hollowed deeper. I have another NE bowl that this difference is much more pronounced, even tho the bark did stay on that one.
Jim, I will try turning one complete when green. Actually the bark is pretty tight--I wasn't watching where the "wings" were when I first started the final hollowing.
>Nice one Roger. I should have a video (free of course) up on the site in a couple of weeks. A bit late for you but someone might like it and you can certainly attest to the fun of the exercise.
