Turned legs
Turned legs
Turned legs
>I haven't had much time to turn lately. I've been doing various commission jobs and of course working. Had to do grip and grin photos of 700 graduates this morning so I was due some time in the shop this afternoon.
My dad wanted me to make the legs for his next project. they are 36" long and 1 1/2" square. This made them pretty tough to turn do to vibration. I built a bowl steady but haven't built a spindle steady yet. I probably should have used it but I was able to dampen the vibration down to a chatter that was easily sanded out with 150.
Re: Turned legs
Good going John!
Jorge Castaneda~Downeast Maine
>36" is quite long and they came quite the same shape :o)
Re: Turned legs
Re: Good going John!
Allen Neighbors
>Doing commission work is the pits, and worth charging for. Doing it for your Dad... priceless. You did well, John. Your Dad could probably pop the buttons off his shirt when he thinks of you. The legs look really nice. :)
Re: Turned legs
Re: Turned legs
Steven Kubien
>John, are the beads spiralled or is my monitor playing tricks on my up-too-late-this-evening eyes? Nice works no matter.
Steve Kubien
Re: Turned legs
Re: Turned legs
tm
>Very nice work John
How are a spindle steady and a bowl steady different?
More than one set of wheels maybe?
Just curious.
Re: Turned legs
Re: Turned legs
>Steve I thought the same thing when I posted them. It must be the lighting. I have a Sears Router Crafter that I bought damaged on ebay. I finally got the idler pulleys fixed but I thing there is something wrong with how the cable is set on the drive wheel. I haven't had time to figure it out. I will be able to turn spirals once I get that fixed.
Re: Turned legs
Re: Turned legs
>A spindle steady usually only has wheels on the backside opposite the cutting force. I've made cam action steadies before and they do work OK but a wheeled version would be much better. I don't remember if I have any wheels left from when I built the bowl stead. Bowl steady usually have 3 or 4 wheels and wrap around the piece completely.
Re: Turned legs
david
>John, my Oneway bowl steady is like you describe in your first sentence, with two skateboard wheels. Others have fabricated their own that may be different. I have no direct experience with a spindle steady, but I believe these are the ones with three wheels that surround the piece to reduce the vibration.
Re: Turned legs
Re: Nice legs..
>I like my spindle steady, it does help with longer pieces. I presume he is going to have mortises in the square portions?
Re: Turned legs
Re: ?????
>David Oneway does it backward from everything I've seen. Obviously works or they wouldn't do it. I think in there ads the bowl steady is different than the steady rests that people use for hollow vessels which usually have 3 or 4 wheels that surround the piece.
I my experience you don't need 3 wheels on a spindle steady. The homemade tapered steady's I've used are simply V shaped and fit on the backside of the spindle so you can still turn that portion. I'll have to look up how this was done because it's been so long since I've used it I don't remember exactly how it worked, but it had a taper so that as you turned the spindle and it got smaller the steady would drop down on the taper and move into the spindle. Sort of an automatic adjustable steady. I need to look that up because it would be really nice to build one with wheels.
Re: Turned legs
I meant to include the Oneway link  *LINK*
http://www.oneway.ca/steadyrests/index.htm
Re: Turned legs
homemade steady *LINK*
>This was in the Lathe Book by Ernie Conover. it's an older book but still has lots of good information. By the Way Ernie will be at the Tennessee Association symposium in January. I think I'll try to build this over Christmas and add some bearings or wheels to the V to see if I can make it work better.
http://www.tnwoodturners.org/
