>I have a rockwell 46-111 I bought used 30+ yrs ago. No manual, anyway the lathe has a four stepped pulley on the headstock and the motor. Well, the smallest sheave on the motor group broke. I'm afraid to check prices through local dealers. Any suggestions? thanks
>I have no idea, except for a little place called Luke's Salvage, here in my home town. What size shaft is the motor, and is it a Vee belt, or one of those with a lot of grooves? What is the outer diameter of the large pulley, and the smallest, and the width of the grooves? I might find one for it here.
I know this doesn't solve your problem, but how often do you use that high speed?
>The bore is 5/8" smallest is 2 1/2" largest is 4 1/2" V groove, A size. I never run the largest, and wish I could slow down even more when turning large chunks. I've thought about building an intermediate shaft system to help slow things down. The price of a variable speed conversion seems too high for my budget.
A year or so back I was in need of one for a Rockwell/Delta and found a dealer of old Rockwell/Delta parts through the Old Woodworking Machines website. I can't recall the dealer's name but if you go to the link and look around for old Delta parts or post asking for a source you'll find it. I can tell you that OEM pulley is around $90. You can also try Emco and Surplus supply for similar but not exactly the same pulleys.
>Turn a wood pulley. I had an old 1920's Oliver with an original wood pulley that was turning a 2" shaft. Use a coarse threaded set screw to attach to the shaft.
>Is your motor 1/2 HP?? There is a 1/2 hp Variable Speed system in Penn State's catalog for about $100, including the motor. It could be easily adapted for almost any Mini Lathe. Don't know what yours is, so just thought I'd mention it.
>I never thought of turning a wooden pulley, before. But Bois d'Arc or Lignum Vitae would both be good wood for a wooden pulley. I'll just keep this on my 'possibilities' list. Thanks for the idea.
>I had a broken cast iron part on my bandsaw, so I decided to glue it with CA. Not only did it hold for a very long time (it's still holding), but it worked so well that when the replacement came, it took me another month to swap it in.
