>loking for information on Delta 1460 lathe. The one I have has an indexing pully. It has a sliding pin with an indexing washer attached to it. The long washer has a hole in it and it turns freely around the pin, is it supposed to be free or tight? Also what does the indexing pin look like? A picture or drawing would be great if possible.
>Try this link. it should take you to a PDF document over on the Old Wood Working Machinery web site. there are several other documents for your lathe over there. From you description it sounds like there may have been some modification to the pin. it is a common thing for them to break off if abused as a spindle lock. The correct pin assymbly is shown in the link. The locking pin that engages the indexing pully is attached to a tab that is mounted to the shaft that is housed in the headstock casting. the tab should not spin on the shaft, but the shaft should rotate freely in the headstock and sould also slide in and out to engage the indexing pully.
I loaned my camera to a neighbor but if no one else posts a pic and you would like one send me a PM and I will get a pic to you in a day or two.
