Yet another DIY handle question
wilbur
>When turning a handle for a gouge, how much wood do you leave around the hole where the ferrule is?
wilbur
Enough...
steve antonucci
>I make sure that the handle fits my hand, and that I have the tool deep enough into the handle that the wood around the ferrule isn't what's holding it together. If you look at some of the tools, it's a 1/4" others, it's 1/8". The ferrule adds so much strength that the wood thickness is irrelevant.
P.S. I have small hands, so my tools are pretty narrow...
Steven
Re: Yet another DIY handle question
Mike Cunningham (Cape May NJ)
>Wilbur,
I make my own handles, most often from Osage Orange and ash. I use 1/2" and 3/4" copper pipe for ferrules, simply use a pipe cutter to cut the length you desire. Turn a tenon on the end of your handle to fit the pipe. Mine are around 1" long, some a bit shorter and some a bit longer, depends on the tool.
Mike
A little larger
tek-Brunswick, Ohio
>I like my ferrules just a little bigger. I use a straight connector for 3/4" copper pipe. I get two ferrules from each one.I chuck it in my talon chuck using #1 jaws, and part it in half with a narrow parting tool. Then I ream where I made the cut. Maybe the extra diameter doesn't matter, but the size just looks right to me. I make my handles similar to the handles on the Crown Tools. They just feel right to me. I know some guys with arthritis like larger diameter handles. Use your favorite commercial handle for a starting point for design and fit.
The guideline I've seen is...
Brian Hahn in SW Wisconsin
>To leave a minimum of 1/4" of wood between the inside of the ferrule and the tool. I sometimes leave a little less for large diameter tools. But then my handles are made from hickory and the ferrule is more of a concession to convention than a necessity. (Ever try to break or split dry hickory?)
Re: The guideline I've seen is...
>The weakest point I think is the top of the ferrule where it touches the wood. As long as your tool goes deeper into the wood than that point you should be OK. I try to put the tool at least 1/1/2" into the wood past the ferrule. At least on bigger tools. Smaller tools like 1/4 nd 3/8" gouges don't have as much force put on them.
I've made a lot of tool handles and haven't any of my homemade ones break. I have seen several factory made handles break and it was always at the point I mentioned.
I don't think I've made any tools with less than 1/8" between the ferrule and wood. My largest ferrules have been 1" in diameter. I think I have about 1/4 or so of wood on the big ones. I'm headed to the shop to get ready for a club meeting. I'll look over my tools and see if there are any variances to what I just said.
>As you can see in this photo my ferrules come in all sizes. The one on the right is my new Thompson gouge that has been well tested. The one on the left is one of my older tools with a longer handle. I push these tools pretty hard sometimes and none of them have brocken. I don't know how much tool I have inserted into the handle but probably 2" total or there abouts.
>Here is my largest tool. As you can see it's pretty good sized. The Ferrule is 1 1/4" thick with about 1/4" of wood on each side of the 5/8" bowl gouge. You don't want to know the abuse I've put this through. This is my rough out the blank that is really out of round gouge. I'm guessing at how far it's inserted into the wood but probably 3"
wilbur
>John,
In the rightmost tool, it looks like you used a brass fairing nut for the ferrule?
Are you concerned about metal/metal contact at that point between your ferrule and the tool shaft, or is there more space there than it seems from the picture?
>Wilbur I believe I used a screw thread to copper adaptor for that. I'm not really concerned with metal to metal but I think there's enough room there for the epoxy to fill the gap so there probably isn't metal to metal. That's my Thompson gouge which also has a coating on the metal.
Thanks!
wilbur
>Thanks for all the replies. I'm going to be using a 1" brass ferrule on handles for a bunch of Thompson tools that got to my house last week.
Why? Because a friend had a cut off piece of 1" brass pipe that he gave me today. That made me stop obsessing over whether to get the 3/4" or 5/8" brass coupling that the local borg had, which prompted my question.
Caution should be exercised
david
>in your choice of metal for the ferrule. Allan Batty was recently here for a workshop and he cautioned against the use of copper piping for the ferrule because it has more of a propensity to split open. The recommended metal for the ferrules is brass, whether pipe and tubing or a threaded connector that you can turn smooth or left as is.
Re: Caution should be exercised
>I've had brass ferrules that split open from seasonal wood expansion.
A more important factor is how thick the metal is and how much strain it is under.
tek-Brunswick, Ohio
>If I am turning poorly enough to split a ferrule, I need a lot more practice! I guess turning a new handle to replace the broken one would be a good place to start. My only tools that get a lot of strain are the tools I rough big pieces of wood with and those do have sturdier handles. The next turning tool I break will be the first one! I hope I didn't jinx myself with that statement. I've ruined my share of wood though.
Thar she blows mate!
tek-Brunswick, Ohio
>You could sign on with Captain Ahab and go after the great white whale with that thing. Harpooner ready? Seriously, I wish my lathe had enough power to use a gouge that big. The 1 horse DC motor on my Nova 3000 would bog down if I tried that big of cut.
