Close call
Close call
Close call
Carole Valentine
>Those of you who use halogen work lights - be careful! I went outside this evening and when I came back I noticed there was a light in the upstairs window. Strange...I had not been up there since last week. I went up to turn it off and discovered it was the halogen work light. It had somehow fallen off the photo setup and when it landed the "on" button got pushed. It was lying part on the carpet and part on a plastic box. The box had melted. The glass cover on the light had gotten so hot it was frosted. It could not have been much longer before something burst into flames. I had to take it out of the house by the cord - it was way too hot to touch. Folks, if you use those things, don't just switch them off. UNPLUG them!
Re: Close call
Re: Close call
Steven Kubien
>Glad to hear nothing worse happened. It reminds of something we are encouraged about here in Canada. When the clocks change with daylight savings time, replace the batteries in your smoke detectors and check your CO detectors as well.
Be safe everyone.
Steve Kubien
Ajax, Ontario
Re: Close call
Re: Close call
Barry Turner
>I had a similar experience with halogen bulbs in a ceiling fan fixture. The fixture was rated for two 100 watt bulbs. I knew halogens got hot, but I reasoned that the fixture was open at the top, the fan was always on when the light was on. I figured the fan blades would help to cool the halogen bulbs. Maybe they did, but not nearly enough. The bulbs got so hot, that the base of the bulb and/or the socket melted, shorted out and smoked up the living room. Luckily, we we home at the time and no damage was done except to the bulb and light fixture. My dealer replaced the fixture and I replaced the halogens with incandescents. I've had no further problems. Halogens put out very nice light. I have a Moffat with a 100 watt halogen on my lathe. But, they really do generate some serious heat.
Re: Close call
scary
GaryG in MD
>It's a good thing you are observant and attentive. That was way too close. Good work, and thanks for the 'heads up'. ...Gary
Re: Close call
Re: scary
Barbara Gill, Remlik VA
>When we were building our house we noticed the smell of wood smoke. After looking around found that a clip on work light was too close to a 2x4; the wood was charred.
Re: Close call
Re: Close call
>Carol Someone up above must be looking out for you if you discovered that in time. Close call.
I was shooting some work in my living room one time and I used a large color correction filter used by the movie industry to change the color of the light to daylight. I've seen the video guys wrap these around the light so I assumed they were flameproof. Still I mounted it 6" in front of the light with plenty of air circulation around it. I turned my back to do something and the thing burst into flames and dropped onto my carpet. Fortunately I had just turned around and saw it fall. I stomped it out and everything was OK.
I guess we can't warn you enough to stay alert when using these lights.
Re: Close call
Re: Close call
Jim Shaver - Oakville, Ontario
>Hi Carole,
Thanks for sharing that. I am so glad nothing serious happened, those lights can get dangerously hot quickly.
Take care,
Jim
Re: Close call
Is there a cooler alternative?
Carole Valentine
>That really scared me and I would like to stop using those hot lights altogether if I could find something cooler that works as well.
Re: Close call
Re: Close call
Brian Hahn in SW Wisconsin
>I quit using halogen lights a long time ago. They get too HOT and I find the strobe effect to be very annoying. I now use incandescent flood lights. Not quite as bright, but a whole lot safer.
How did the light get knocked over? Do you have gremlins in your house?
Re: Close call
Re: Is there a cooler alternative?
Mike in Savannah
>Carol,
Yes, there is. First you can easily use plain old florescent lamps for the light source in both still and motion photography AS LONG AS they are ALL the same type, as in color temperature. The green cast they are disliked for is very easy to correct to normal. If you have the bucks, the professional version of this is called a KinoFlo. It is basically florescent lamps corrected to match a tungsten or daylight light. But, again, the key here is to not mix types (colors) of light sources.
An altogether different approach is to get into the habit of just unplugging anything you don't trust. Personally I turn off all my shop circuit breakers and/or unplug things. As an engineer I've been exposed to how much of these things are built. I don't trust most of them particularly around innocent kids, pets or accidentally falling objects, particularly those with infrared or RF type remote controls.
Mike
Re: Close call
Re: Close call
Carole Valentine
>I have no idea how it fell off. It was sitting on the photo table (not a stand). I have a cat but the door was closed so I can't blame her.
Re: Close call
Re: Close call
>Thanks for posting the warning.
I had one of those upright versions that shined straight up. Sort of a bulb in a metal saucer. In stead of throwing it away, I put it in the shop, near the lathe. Worked great for general illumination. Like a 100 watts or maybe it was 500 shining straight up on the ceiling, reflecting back down on my work. Did not use it everyday. A few well placed ribbons off the lathe and a little dust. Plugged it in, Camp fire. Glad I was there. Carried it outside. Let it cool down and into the trash.
Glad you found yours in time.
Re: Close call
R30 Compact Fluorescents *LINK*
Roger Smith
>are not as hot. FE-US-55W/50 (equal to 250W incandescent) is 5000K daylight balance bulb that screws into a regular light socket. There are other models that range from 12W to 50W. Uses less power and last longer. I got mine from replacementlightbulbs.com 800.692.3051.
Replacment Lights Bulbs
Re: Close call
Re: R30 Compact Fluorescents
Carole Valentine
>Looks like what I want, but it's little hard to stomach $16 in shipping for two light bulbs. :(
Re: Close call
>After reading your post I thought I would just buy a couple and try them out but it's going to run over $50 to get to lamps. Of course you still have to buy reflectors to put them in and adapt those to stands.
I've shot with daylight balanced flourescents and they do work very well. If your just starting out that may be the way to go but it's a little expensive.
To get around Carol's problem, the lamps I buy are really inexpensive and don't even have a switch. I plug them into a fused power strip and then turn the lights on and off using that. In fact when I demo I have 3 lights and power strips for each one so I can turn them off from the camera position. It makes the demo go faster.
Re: Close call
You might want to try daylight fluorescent *LINK*
Jeff from MA
>The primary lighting for my shop work area and my digital photography work area is from daylight balanced, high output fluorescent bulbs. These bulbs throw much more light than the standard fluorescent and the quality of the light makes it easier see see the small details (in my case that means tool marks and and scratches) in the work. If you do decide to change bulbs please remember to compare the output of the light bulbs under consideration measured in lumens. Most people only look at Watts which measures power consumption rather than output. The daylight balanced bulbs are more expensive but they last much longer.
So you can get an idea of the output and quality of the light I attached a picture below. The picture was taken in my windowless basement shop, with the fluorescent lights as the light source, without a flash. I put a link to where I purchased my bulbs below.
I also use halogen task lights (2 used dental lights, and one magnetic base light) for directing light inside of work pieces. Even with the shields around the bulbs dust on the hood, or a loose wood shaving will get pretty hot. You definitely have to be careful.
Light Bulbs
Re: Close call
Another Story
Ron in Drums PA
>I'm glad everything is ok.
A daughter of a friend of ours hangs up her hair dryer on one of those suction cup hooks. She never unplugs it from the wall.
One day the suction fails and the hair dryer falls onto a rug. The fall knocks on the switch. Luckily the mother comes home and smells something smoky. It was the carpet beginning to smolder. They were lucky someone caught it in time.
Re: Close call
How much is your insurance deductible?
Stuart Johnson
Re: Close call
That is scary!
Re: Close call
yet another story
jared
>Last fall I was having trouble with my milwaukee angle drill that I use for sanding on the lathe. It got noisy and thenwouldnt run up to speed and finally quit altogether. Nothing really visible or smoking. I laid it down on the bed of my lathe and got busy doing something else in the shop and a few minutes later I heard something, the drill had started running on its own and falled off the lathe into a pile of shavings that were under the lathe. This time the drill was smoking and sparks were coming out of it. The on off switch was not locked on but must have somehow shorted out and started the the thing running. IF I hadnt been there, I am sure the whole place would have burned down. Now I have the outlet for the drill wired into an on off fuse box that the lathe is connected to, along with all of the lights that I have on or aimed at the lathe. I turn it on when I use it and off when I leave. Protects the lathe from lightning/ voltage surges and shuts all of the rest of the stuff off. Jared
Re: Close call
Re: Close call
Don in Central Illinois
>Glad you caught it in time and all is well and safe. The only good thing I can think of that happened is that you said the glass got frosted. As photographers, we like to shoot through frosted material.
Re: Close call
Re: Close call
Mike Schwing from Md.
>WOW! What a close call indeed! I think those things are misnamed. Instead of calling them halogen work lights, I call them firestarters. I never feel comfortable when I use them. One of these days I'll divert money to purchasing proper diffused lighting, hopefully before the house burns down.
Re: Close call
Roger Smith
>The advertised life is 8000 hours. Everyone fluffs so, say it will last 2000 hours. I spend less that 2 hours per week using the lights. That is about 20 years for me. How many Halogen will you have to buy in that time?
Re: Close call
Re: HALOGEN STAND LIGHTS
Bill Hale / The Wood Spinner
>For those of you that do use the Halogen lights that are on stands or mounted.
Be sure to remove the wire frame work in front of the glass.
A couple of years back I posted that the shavings can get hung on the safety wire frame on the front and will start to burn and drop to the floor.
All of my shop lighting is on plugs on the ceiling. I use x10 for control but I also have the plugs wired to a wall switch that I turn off as I leave the shop.
Good turning and as always be safe
Re: Close call
Re: Close call
Jennifer@Indy.USA
>OMG! Carole...that is scary to ponder. Glad you saw it. That could have made for a bad day.
Jen
