Another crush grind question
Bart Rhoads
>I recently received my crush grind mechanisms I had ordered. But I am a little confused. The instructions that came with them show removing the clips that are supposed to hold the mechanisms in place and using epoxy to glue them in instead. The original instructions show making a recess for the clips grab and hold the mechanisms in place. Can someone explain the reason for the change of instructions or why one is better than the other? Thanks
Re: Another crush grind question
Prabably because
david
>The recess had to be made perfect for the friction fit to work well, and the torque from the turning action could loosen the fit when temperature variations caused any kind of expansion and contraction. Even with the right size bit, the hole drilled can get oversize very easily. Too much precision required here. Glueing the mechanism in place solves most of those problems.
