You don't have to have hands on instruction
Rick Allen
>Hi Julie
500 RPM is slow. Faster is likely going to make the process easier.
The bowl gouge must be sharp. A dull gouge and slow speed is much more likely to result in a catch. A bowl gouge is usually sharpened a couple of times for each bowl turned.
The techniques you see on videos are difficult to replicate if you have no frame of reference. The videos make a good reference to improve your skills but not so good at establishing skills.
There are a lot of woodturners who are self taught. You don't have to have someone show you how to use a bowl gouge. However, hands on training will put you 6 months to a year ahead.
I know several woodturners who use a scraper to turn bowls. They are as quick with a scraper as I am with a bowl gouge. If the scraper is taking you a long time you might want to:
Increase the lathe speed
Sharpen and put a bur on your scraper (a scraper needs to be sharpened a lot more often than a bowl gouge to effectively remove the same amount of wood).
Sharpening: The quickest way to learn the difference between a sharp tool and a "dull" tool is to have two identical sharp tools. Cut with one of the tools until you have some difficulty. Switch to the known sharp tool. If the difficulty goes away then the difficulty was likely caused by a dull tool. If the difficulty remains then the sharpness of the tool was not the issue. In a few weeks of turning you will have a solid feel for when your tools need to be sharpened.
There are many other possible reasons for your difficulty.
Most bowls turned in English speaking countries are turned from wood where the bottom of the bowl represents the bark of the tree. In many non-English speaking countries the bowl is turned from a cross section of the tree. The techniques and tools used are different.
The shape of the bowl contributes to ease or difficulty of turning.
Turning unsupported wood, especially green wood will result in catches and worse. Working the rim area to completion before removing the wood closer to the center of the bowl helps eliminate this issue.
