>I'm having trouble putting on brush on poly on some peppermills. What happens is no matter how light a coat on put on I end up with some finish sags or runs spots. I sand to 400 grit. Is there a better way to finish peppermills? I'm using the correct brush. Can't firgure why I get the small run spots. Thanks for any help.
>I agree with Stuart. I thin my poly finishes until they are of wiping varnish consistency, flood it on and then wipe it off with paper towels. I actually try to dry the poly by friction polishing it on the lathe. Don't use a cloth; too dangerous if it gets caught.
You can usually get several coats applied in an hour. Then you just have to cover it so that the poly dries in a dust free environment. I polish it after it dries with a white 3M pad and wax.
>A cabinetmaker I consulted on finishes suggested that on small projects, I should consider Deft lacquer spray in a aerosol can. Even coverage on a rounded surface is an issue, but for small bowls I made a lazy-susan of sorts and rotated the object while I sprayed from the can. Several light coats works better than a thicker coat that will run...OOOPS.. After drying well, runs can be sanded out if done carefully. When I try to hurry a finish along is when I tend to mess things up.
