Over the bed Tool Rest *LINK*
david
>This is a handy rotating and sliding platform I devised to anchor the end of the bowl gouge when the angle of attack on a medium depth bowl places the gouge over the bed of the lathe. By firmly anchoring the end of the gouge, you can overcome the initial grab and torque that can be generated when the metal first engages wood. I can return to any part of the interior with confidence and take very small cuts at random. This rest has enhanced my ability to work on bowls with very thin walls. Photos and narrative can be found in the Honolulu Woodturners website, Tips and Techniques section.
HNL Woodturners Tips & Techniques
Re: Over the bed Tool Rest *LINK*
>David That's very interesting and I applaud your inventiveness. Perhaps I'm too slow this morning I'm afraid I don't see the advantage. I am constantly moving the handle to achieve the best cut. When I need to take a small cut somewhere on the inside I simply place the bevel of the tool on the bowl and adjust the handle so the cutting edge isn't cutting. Then I move the handle very slightly while moving the tool back and forth over the area where I want the cut to start. By moving the handle very slightly I can gently find the position where the cutting edge just starts to cut. This allows me to take off cuts thinner than a piece of paper. There isn't any real torque because I'm taking a light cut. Depending on which part of the bevel I have the tool and where the flute of the tool is, the handle could be anywhere to start the cut.
Perhaps some of us
david
>week-end turners are not as skilled riding the bevel and need a little extra support. All I can say is if you think it could help, then try it--it is not a difficult setup to make. With this rest, I can approach the wood without riding the bevel first, because I know how steady my cut will be. I now consider this part of my arsenal, just like the bowl steady rest. Both require a little set up time, but to me at least, the benefits are worth the slight hassle.
Ron in Drums PA
>David, I think I would have to agree with John.
I move my handle all the time, not only left and right but up and down also. There are even times my handle is below the ways, other times perfectly horizontal.
This has nothing to do week-end turners, but about tool control.
Riding the bevel is a good thing, I think your time would be better spent learning how to approach the form then setting up your rest.
Re: Perhaps some of us
>Not having used one I jumped to conclusions. It's not that far removed from a captured boring bar system. Are you actually riding the bevel of the tool when you approach it this way or using it like a scraper.
When I'm really nervous and don't want to try a bevel rubbing cut I'll use the gouge with the flute facing the bottom of the bowl and scrape with the bottom lip of the bowl. This allows a lot of very fine control with little chance of a catch.
Anyway I like the fact that your trying to find solutions to problems. I'd love to stand beside you and watch you cut, with and without this tool to see if I can see the problems.
Your ticket is in the mail, John,
david
>and if you believe that I think there are some nice land in Florida that might be available, alligators included ;-). Allan Batty will be at my shop this week-end conducting two hands-on workshops, and if the opportunity presents itself, I will show him my gizmo and see what a traditionally trained expert says.
Re: I understand it, David.
Allen Neighbors
>When I had Old Griz, I was always turning deeper vessels for some reason, and I had one of these... sort of... that I used to hold the heavy end of a long tool (some well over 3 feet length). Mine was a 2x4 of pine, offset like your bottom piece, but it was turned on edge, with a bolt through it, with a large concave washer to tilt on, above and below the ways. I had a pin in the offside end of it, to keep the tool handle from coming off the rest inadvertantly. It worked like a charm. I could start the cut anywhere I wanted to, consistantly, and still ride the bevel. Just rest the handle on the rest, the tool on it's rest, with the bevel riding, and rotate the tool for the cut.
I think yours is better than mine. Good job.
Re: Your ticket is in the mail, John,
>On a scale of 1 to 10 I would be about a 2 and Alan an 8 or 9 so I would definitely ask him. I'm jealous. I've met Stewart Batty and they don't come much nicer than that. Alan would be great.
