Alder Bowl - Finish Questions
Ed Larson
>This is an alder bowl 6 in by 2 1/2 in turned wet, dried, sanded to 400 and finished with walnut oil but not buffed. It was pale pink prior to adding the finish. Will the bright ornage color last?? I have some face grain bowls ready to be finished and welcome comments on possible finishes. I have lacquered a scrap and the orange color is not as bright. I also like the pale pink color of the unfinished bowl. Any comments on finishing, the design of the bowl or the photo welcomed.
Re: Alder Bowl - Finish Questions
Steven Antonucci
Generally speaking, a good bowl
steve antonucci
>I hope that you secured the little knot with some glue prior to finishing. I've had some fall out as the bowl gets "truly dry". CA is not waterproof most of the time, so gentle wiping vs. sink cleaning if you decide to use it.
Personally, I think the foot is too big for the size of the bowl. As a general rule of design, a foot should be 30-40% of the width. I also think that the foot is a tad tall for the profile. The bowl will still be stable if the foot was smaller and lower, and you would see the form a lot better.
2 cents.
Steve
Troy German
>Ed your picture is great. I hope I can get results that good someday. For a WC post you could crop out much of the background, but that�s pretty minor.
As far as alder goes, I like the many colors the wood takes as it dries as well, but I�ve had no luck controlling the color change. My experience is very limited, 3 pieces turned wet and 1 dry. The dry piece had no color change at all. Of the 3 wet pieces, I only completed one of them. I finished it with carnauba wax and the light yellow color did not change at all.
Again, great picture of a good looking bowl, and good luck with the finish.
Troy
Ralph
>I've never had the colors last in the red alder I've turned. Well, except for the dark color caused by early rot.
This form and the foot being what it is,
david
>has a certain appeal, IMO. It harks to the traditional European and Scandinavian forms. Not all bowls must follow a set or prescribed formula--if the walls were higher, then it would be a different story. I like it...
