Threaded Walnut Box
Threaded Walnut Box
Threaded Walnut Box
Mike from St. Clair Shores
>Here's another box that I recently threaded. I did this one in front of 30 turners at a meeting of the Michigan Association of Woodturners. They asked me to do a demo at their October meeting. Needless to say I was a little nervous and wanted to do a good job on the threads. I was trying to take my time and do all the steps like I would in my own shop. Well it worked and the threads were perfect. The nice thing about using this jig is that it doesn't care what type of wood you use, it just cuts nice threads. The box is Black Walnut, 5"X
2 1/2". Comments Welcome.
Mike
Re: Threaded Walnut Box
Inside Threaded Walnut Box
Carol Reed - in Nebraska
>"this jig" ???
Which jig?
Mike Stafford
Mike Stafford
>That is a great looking box, Mike, all the more so that you threaded it. I have not ventured into threading yet but it is on my "to do" list. Just a lovely little box. I have read that threading the lid makes turning it so much easier. True?
>Mike,
I have been reading your post and seeing all the beautiful boxes that you make. Since I made my thread jig I'm having a lot of fun doing the threads. And you are right, it does make finishing and turning much easier. The lid can be finish turned while screwed on to the bottom. I wanted to do this for quite a while but just couldn't justify the money for the ones that are commercially available. Since I had the router and the cross slide vise and the scrap wood, I've only got about 50 bucks invested.
Thanks for the nice comments.
Mike
Re: Threaded Walnut Box *LINK*
>Carol,
I first started to think about making my jig after I saw an article by Al Crandall of the Central Indiana Woodturners. I've included a link, but you have to look at all the pictures and read all the descriptions to see how Al made his. I hope that helps.
I have also included a picture of the one I made.
MIke
P.S. I hope That Al doesn't mind that I am giving him all the credit.
Threading Jig
>Thanks, Mike.
I had saved the info on Al's jig. I have a cross slide so when I get around to mkaing mine, I will use it. I like your adaptation.
Re: Threaded Walnut Box - 1 more ?
>Part number and source for the cutter?
Thanks!
>Carol,
I copied this directly from the Central Indiana Newsletter.
"The cutter shown in the router spindle is a 3/4" diameter 60 degree hss Double Angle shank type cutter with a 3/8" diameter shank. It was purchased from Enco. Their model number is 367-7100. On line shopping at www.use-enco.com will get it for $21.24 plus shipping as of this writing. Be aware that the 3/8" shank will probably necessitate the use of a collet bushing in the router. Another option would be to buy a 1" diameter cutter which has a 1/2" diameter shank. This cutter number is 367-7102 from Enco. I know of no source which has a like cutter with 1/4" diameter shank."
Mike
Steven Antonucci
Love the box, but it looks "painful"
steve antonucci
>Do you think that it might be viewed as dangerous to open? I can already feel the little indentation in my hand...
I'd like it better with a smoother top... but that's just me.
Steve
dwr
>Mike,
I have been procrastinating for quite a while in making Al's jig... now seems to be the time.
Questions:
1. How do you ensure that the grain is aligned when you cut the threads? Can you elaborate on what you do?
2. Is it critical that the cutter/router is at a "specific" height in relation to the center height of the chuck holding the box?
Thanks!
>In order to make the grain match, I turn about 1 inch of threads in the lid and only about 3/8 inch plus the recess on the bottom. I don't know if this is the right way, but it works for me. I just keep screwing the lid on and checking the grain orientation. I can then just keep cutting a little off the lid opening until I get a match. Did I explain that good enough?
It seems easier to do than talk about. The answer to the second question is I lined up the center of the cutter and the threaded rod center and just made sure that they were in perfect alignment. Really not that hard to do, just seems like it might be. I was so glad when I stopped thinking about it and just did it, because it works really great.
Good luck,
Mike
