Morse taper on a drill chuck
Michael Brady
>I purchased a drill chuck on a #2 Morse taper at WC to use with my Jet mini. I am not much of a turner, much this accessory seemed to have many uses. I know that the chuck is used mostly in the tail stock, but I can see applications for it rotating in the headstock. My problem is that the morse taper does not want to seat in the head stock female taper. It's like it bottoms out before seating. Works fine in the tail stock. Could some of you with more experience tell me what is going on?
Re: Morse taper on a drill chuck
Brian Hahn in SW Wisconsin
>It seems that the Jet mini has a short taper in the headstock. I had trouble with a couple of drive centers that didn't want to seat. With a drill chuck the problem also can be because the tang at the end of the taper is too fat to fit into the spindle bore at the end of the taper. If the chuck stops well short of seating, then it is the tang and you will need to file or grind the sides of the tang down until the tang fits into the bore through the spindle. If the taper is very close to seating, then you will need to shorten the taper by grinding or filing the sides at the very end of the taper to reduce its diameter (and thus its length). I had to relieve (grind to a smaller diameter) about 1/8" at the end of the taper on my two drive centers.
Re: Morse taper on a drill chuck *LINK*
Jerry Hall
>If your morse taper has a hole tapped in it then you can build a "draw bar" of the right length made with Threads-all with a handle fixed to one end for tightening it up. This will fix it safely in the drive spindle. Or you can bring up the tail stock. If you don't use the tail stock or a draw bar then you would be ill advised to use it as a drive. It will spin out and create excitement. Packard Supply used to sell a chuck tapped for a draw bar. Craft Supply doesn't. They advertise some of their chucks for holding and driving work, but they don't have provision for a draw bar. Doesn't make sense to me.
The link shows another source for MT2 drawbar jacobs chuck $29
Draw bar Jacobs chuck
E.T.
>I drilled out the shaft on my General Maxi lathe 25-100. It had the same problem with regular MT"s bottoming out. Another General owner told me how he used a drill in a chuck in the tail stock, so that is what I did. A 1/2 inch drill gave me the clearance I needed. I went in about 3/8 inch. Now I can use any #2 MT accessory.
BTW General sold a Jacobs chuck on a special short #2 MT to fit these lathes with the short MT in the shaft. ET
Michael Brady
>Awesome guys. These are the answers I need. Quite frankly I got nothing in the way of advice from another large WW forum. Maybe turning is just not their thing.
My MT is tapped at the small end, by the way. I have to admit this turning stuff is fun and the results are there right now instead of weeks later, like in other modes of WW.
