A55 Smoothing Plane
Bowl Steady - finally
Chip in Plano
>I finally built something I've needed for over a year. I hate building jigs. I built so many jigs when I was doing flatwork, I have a mental complex about them. But after tossing several pieces in the 'someday I'm gonna fix it' box or the firebox, that I finally did it. I made it oversized for my 14" Jet so figuring out the length and position of the rollers and arms was interesting. In the end, I left enough clearance to allow my Monster Laser HF jig to poke through for most pieces. The 2 lower wheels will fully recess so I can almost turn to full capacity. For anybody else who have lost a piece (or 6) due it being insufficiently supported when hollowing build one for yourself.
Now if I can just finish my segmenting tablesaw sled ala Malcom Tibbetts.
Re: Bowl Steady - finally
eliot d
>It looks functional. Really nice work! Reminds me of the metal one by Dr. Keith Clark -- the Spin Doctor . But his costs something like $300.
David
>Chip,
Nice setup. Looks like you can handle any size. For those of us who are less mechanically inclined (i.e. me) can you explain the hardware setup especially the axles for the wheels? Thanks
Bill Hale / The Wood Spinner
>Chip
two questions
It appears you are using a pipe clamp to hold it to the ways. Is this a correct assumption ?
How do you hold the roller arms to the main body of the steady ? Most I have seen have a slot in the arm and a bolt through the body and arm.
Good turning and be safe
Thanks Bill in Casa Grande, AZ.
Allen Neighbors
>Nice steady rest, Chip. I see you like the Baltic Birch, too. Good stuff. I'd like to hear more about your wheels and axles, too.
Chip in Plano
>Yep, the pipe clamp is what clamps it to the lathe. This was the backup option. I mis-judged the throat depth on another clamp and came up short. I also lost patience trying make a reasonably tight fitting clamp block. I've got a hunk of lyptus somewhere in the shop that should do the job when I get a round tuit. More likely I'll just buy the large throat pony-style pipe clamps that Grizzly sells and clamp from underneath.
Again, I lost patience and opted to not do the slots because I would have had to go get new hardware and clean/dust off my router table. I already had T-nuts and wing nuts so I opted for a friction fit. The wing nuts pinches the wood again the upright base. 3 of 4 sides of the block-assembly the arms pass through are lined with high-density 'plastic' tape. The arms slide reasonable well. I routed recesses so the T-nuts didn't bind the arms. When the arms get worn out from the wing nuts, I'll just replace them. I used screws just in case I needed to redo something.
I still need to cut the top arms since they are a definite hazard to my face. My face shield has saved me a couple of times.
Chip in Plano
>I got the wheels out of the mark-down bin at Sports Authority. They didn't come with bearings which I didn't notice and had to make a second trip. I was going to cannibalize my kids skates but they were dirty and grit-embedded. I tried the belt sander to clean them but didn't like the outcome. I feel better with clean wheels. I hused 5/16 hex bolts with a nylon nut and washers at each end. There's another metal washer and a nylon washer between the wheel and the arm. They nylon washer is against the wood acting as a spacer. Tightening is tricky because the wheel needs to spin but the hex bolt doesn't. Because the opening is offset, to set the wheel positions, I used the tailstock and a live center and
putz around then carefully marked their locations
The baltic birch was originally bought for my segmenting sled but that was made from MDF. It was on hand. I glued 2 1/2" sheets together then jig-sawed the shapeIt seems stable enough. It would be easy to reinforce it needed.
David Breth
>Thanks for posting that, Chip. I've been contemplating making a steady for myself for some time. Looks like this has potential.
Now we'll see if I have kinetic.
David B.
