Canoncamer S60 (OT sort of)
eliot d
>I can't figure out how to import pictures from this thing. I plug in the connector to my MAC PowerBook G4 computer and try to fool around with the camera until I see the picture I want and then click on 'IMPORT". But nothing happens. I think it's more of a camera problem than a computer problem. Help!
Re: Canoncamer S60 (OT sort of)
Stuart Johnson
>First off I don't have any idea of what I'm doing and usually have to ask for help. But, is it possible you are accessing the camera menu? If so you might be trying (as far as the camera is concerned) to import a photo to it. Does the menu have an export option?
Now maybe someone that knows what they are talking about will give you some sound help.
Re: Have you loaded the .......
Jamie Donaldson
>....camera software CD? I'm no MAC or Canon expert, but the computer probably can't read the camera image files without the proper software installed.
david
>Eliot: My home computer is an Imac. Are you trying to import photos from your camera to I-photo? Assuming that you have all the connections made properly. If the files are large, it will take a while to for the program to recognize that a camera is connected and you are ready to import. When it is ready to import, at the bottom left it will list the camera memory that is connected and designate how many images are available for import. When you select import, you may be asked if you want to retain the images in your camera or if you want to erase them. Once all the right buttons are selected, photos will begin to appear in the Iphoto window. Sometimes I have to totoggle back and forth between Import and Browse before my camera comes up on the bottom left. If you downloaded a photo of your piece and want to post it on this board, you will have to copy it to the desktop and use a photo manipulation program such as Photoshop to get the file size down to under 80 kb. You need the photo file to be on the desktop so when you select the Optional Graphic Upload Browse button, you can find it on the desktop. Email me offline if this doesn't help and we can work on it step by step.
eliot d
>Hi David. I remember you: I believe you have an exchange piece I made. thanks for the camera/computer tip. I'll have to try it and get back to you.
