Making Tools: Brass 360 Follow-up Part 1
dwr
>I got some Brass 360 Alloy and Aluminum to make my own shot filled tool handles for my Doug Thompson Tools.
1. I cut the Aluminum to 24" in length (can shorten later as needed).
2. I cut a 2.75" length of Brass 360 Alloy bar.
3. Insert the Brass 360 into the center of my "antique" Raffen Chuck... fits like a glove.
4. From there I drill out the center for 2" to accept the tang of the DT Tool. Set the VFD Control to 30 cycles and it drills real nice on the old gap bed lathe.
Re: Making Tools: Brass 360 Follow-up Part 1
Part 2
dwr
>1. Extend the Brass and bring up the live center.
2. Pare down the brass to the proper diameter for the Aluminum.
3. I used an unhandled HSS Cutter and tool handle I got off Ebay a year ago, to turn the Brass 360.
Part 3
dwr
>1. Reverse the Brass into my Stronghold Chuck to finish turning the rest of the Brass Insert and shoulder.
Part 4
dwr
>1. Brass 360 Insert pressed into the Aluminum and getting chamfers and bevels.
2. Mounted back into the Raffen Chuck using inner diameter and live center.
3. After finishing the end, I sand several grits to remove scale and give the tool a good finish.
Part 5
dwr
>1. Here is the full length set-up of the handle in the lathe getting the bevels, etc, before sanding.
Part 6
dwr
>1. The finished handle with the Brass 360 insert. Sanded and polished a bit and ready for a DT Tool.
2. Will add two set screws to the handle to hold the tool in place.
Part 7
dwr
>1. A DT 3/8 Detail Gouge installed. (Sorry about the picture quality...)
2. I loaned all my larger bits out and have to wait to drill out the insert to 1/2".
3. I am making four handles for 1/2" and 5/8" diameter shanks.
4. Will need to add plugs to the other end after deciding on and cutting to final length.
5. Plugs will have threaded insert to add and remove shot for weight and dampening.
6. A little work and I have Aluminum shot filled handles for less than 1/5 the price of commercial handles.
7. I will be making smaller handles for the 3/8" DT Tools and for some mini-hollowing tools.
Very nice photo essay. Thanks.
Brian Hahn in SW Wisconsin
Re: This is a very nice photo essay Dave.
Jamie Donaldson
>I haven't seen one of those old 4 Combination chucks in ages, let alone anyone who actually uses it! I remember giving mine to a poor chuckless soul after the original Nova came along- wonder if he ever used it?
Bill Hale / The Wood Spinner
>Isn't that AL going to make your hands black ?
Bill in Casa Grande, AZ
Jamie... Thanks...
dwr
>... that was my first chuck 20 some years ago... It was "The" chuck at the time. I actually bought a machinist three jaw from CS when they sold them. Couldn't keep anything mounted on the bloody thing so it went back and I got the Raffen chuck...
It was all I used until a few months ago. I had 25% off at Woodcraft... so I splurged and got the Stronghold for the big bowl lathe that just got completed...
Dave
Bill, I am going...
dwr
>... to coat it with some Lacquer when I get it filled, plugged, polished and cut to final length.
If that doesn't last then it will get a DIY powder-coat job...
Dave
Re: Shucks- I could have made you...
Jamie Donaldson
>...a real deal on a 3 jaw chuck I recently found in the bottom of one of my tool caches- dang thing must weigh about 20 lbs!
I envy those that have...
dwr
>... some metal working tools in their repertoire of tools.
I spend 4 hours turning Brass and Aluminum by hand on a wood lathe... that would take 15 minutes on a metal lathe...
I gotta keep checking the old Craig's List.... someone will give a small one away someday...;) then we can talk about your chuck!
Re: Dave, do you have a Nova also?
Allen Neighbors
Collet Chucks & 3-Jaw Chucks...
Wally Dickerman in Arizona
>I still have a collet chuck that you refer to as a Raffan chuck. It is actually a very good chuck but it has a very limited adjustment range. I also still have my heavy 3-jaw chuck. Both of these were popular back in the 80's before the modern 4-jaw chuck came out. I still use my 3-jaw. It will hold most anything that's round up to a bit over 6 inches in dia. Very easy to install a bandsawed blank to set it up for a 4-jaw or a glue block. Fact is, I still use a lot of the "old stuff" in my turning. Just because it's new doesn't necessarily make it better.
Wally
Wally, I agree...
dwr
>... that's why I kept the Raffan chuck. I was fairly new to turning in the early '80s and learning to take a decent cut on a three jaw chuck was a steep learning curve at the time.
And yes, the adjustment range on the Raffan is VERY limited (can't tell you how many time I missed the diameter on the tenon...;) Got good at "shimming"!
Dave
Allen, yes, I did...
dwr
>... break down and get a Nova recently (another Woodcraft major discount price) for the Midi-Lathe because all my other fixtures were 1.25 x 8 and I needed a 1 x 8. I do miss the one-handed scroll action but this lathe doesn't get used that much.
Dave
Re: Bill, I am going...
Doug Thompson near Cleveland
>Good job Dave! I would fill the entire handle with shot or sand to give them some weight. Lacquer will work on aluminum but a clear manifold paint remains clear and holds up longer. When you get the set completed post a picture.
Good Job!
Re: Dave, will you check something...
Allen Neighbors
>for me? I would surely appreciate it. A friend told me that his Stronghold Jumbo jaws fit on his Nova Midi Chuck.
Will you check to see if any of your Nova Jaws will fit on your Stronghold Chuck?
(I'm going to buy a large chuck that has the same threads as my Oneway Lathe, and I already have two SN2 Chucks, [I'd like to get a chuck without having to Special Order it], and I'm thinking about a Stronghold, but I don't want to lose the use of all my Nova Jaws. If the Nova Jaws won't fit the Stronghold Chuck, I'll just order a Nova Titan).
Re: You make me want to ..
Allen Neighbors
>hide all my handles. :) Exceptional job.
Dougie...
dwr
>... I did the Ash handle routine and the weight was not there and the holes were not straight and no decent way to make the blade removeable... so to do your cool-tool justice, I had to go-pro with the Aluminum Shot Filled Handles!
$$$ for commercial handles were out of my price range.. so it was DIY Time. The Brass 360 turns by hand better than I thought it would. It also gives the front some nice weight... looks nice too!
Will post pictures of the sets as I get them done. I think I can do a set of 4 handles for the big tools, 2 for the smaller tools and 4-6 for some mini-hollowing tools for the price of two or three commercial handles...
Wish I had a bench-top metal lathe...;) If you come across one for a "song" + shipping, Doug, give me a shout.
At least I have a Mason Jar full of Brass Filler for inlaying and resin pressure and vacuum casting!
We need to get caught up Doug. I will give you a ring in a few days.
Dave
Allen, I will...
dwr
>... check it out as soon as I can and e-mail you back. Might be a day or two...
Dave
Allen, if you saw how my Ash ...
dwr
>... handles turned out, you would appreciate why I went with the Aluminum and Brass. Handles were shaped fairly well, but my holes for the tools were pathetic... Forget about "6� of Separation" ... these bad boys were all over the compass! 15�+ off center made for some interesting turning positions on the bowl lathe!
Dave
Re: Thank you. Very Much! :)
Allen Neighbors
