opinion on a chainsaw needed
Steve Kubien
Steve Kubien
>Hi everybody,
I will soon be looking at a gas chainsaw and an opportunity has fallen in my lap. A friend is looking to unload a Stihl 025 for $200 Cdn. My (sizeable) gut is telling me that this may be too small (power-wise) for slabbing bowl blanks but I wanted to get you thoughts. Being on a budget, will this saw suit the purposes of a turner who likes green, found, wood for bowls and plates in the 10-20" diameter range? Will it frustrate me to no end? Will I burn it out?
I am not looking to start a debate about which brand is best. Just looking at usage for a particular saw.
Thanks for your help,
Steve Kubien
Re: opinion on a chainsaw needed
Roger in MO
Roger in MO
>My 025 is probably 8 to 10 years old and has been used extensively to cut hedge posts and fire wood. I've also slabbed some green wood for bowls. My 16" blade would be challenged to handle slabbing 20". If you a lot of the big stuff it might be a bit small.
Brian Hahn in SW Wisconsin
>I have an even older Stihl 011 with a 16" bar. It has enough power to slab a 24" chunk of oak, BUT the shavings can't clear the chip ejection port and it continually plugs up.
JKJ in East TN
>Steve,
There was a thread just in the last few days concerning the 250 (basically the same saw as the 025, I believe). To repeat somewhat, I've had a 250 with a 16" bar for some years. This saw has plenty of power (with a 16" bar) and I've used it to cut some fairly big blanks and trees. You MIGHT be able to get by with an 18" bar but certainly no larger.
I especially like the light weight and balance compared to my larger saw. I think that makes it safer, not only for limbing and bucking trees but for cutting blanks. I don't think 20" wood is too big for it, but you will have to cut from both sides. A straight cut through thick wood can be made by using the initial kerfs to guide the later.
Re: opinion on a (025) chainsaw needed
Mike Jones
>I love my 025!! I replaced some of the Waterford Crystal in the china hutch with it,(fit nicely) but my Marianne, she...well that's another story. Keep that chain sharp and let that little baby do the work! Of course it is slower than my 044, but much handier. the 44 usually stays home now unless I know that I am going to be doing a lot of cutting on a large bole.
Steve Kubien
Thanks everyone
Steve Kubien
>Well, the price is right and I trust the guy I am getting it from so I think I will pick it up. It would be nice and convenient to spin a 20" chain but not REALLY necessary. My electric has a 16" bar and has served fine in the shop.
Thanks a lot for your comments.
Steve Kubien
