Norfold Island Pine Question
Barbara Gill, Remlik VA
>How do you Norfold Island Pine turners light the inside of your finished piece for photographs?
Re: Norfold Island Pine Question
Jorge Castaneda
>Barbara,
just stick a lightbulb inside, a low wattage one, 25 - 40 is all you need when tuning to see uniform thickness, I imagine something similar is used for photos, or maybe just backlit once is saturated with oil.
What I do is...
david
>wait to take the shot at night or use a very darkened room. My camera is on an easel and I use the self-timer for shutter release. The exposure is set on automatic and the easel is back a bit so that I have to zoom in to fill the frame. I have used anything from a reflector flood to a plain incandescent lamp, held above the piece and beyond what the viewfinder can see. In a pinch, even a flashlight will work. The camera will expose for 2-3 seconds and the piece will be mostly in profile, but glowing from within. The top of the piece will have hot light like sunlight. If I had more lighting control, I would try to get some soft light on the exterior, but haven't figured out a setup for that yet and what kind of lighting controls would be required. You can put a light bulb inside the piece if it large enough, but in the photo you will have to figure out how to erase the cord on the rim.
Thanks Jorge and David.
Re: The easy way is to shine.....
Jamie Donaldson
>.. a spotlight from straight above the bowl, but don't allow any light to spill over the rim onto the area around the bowl. Some spots work better with a snoot(a metal tube around the light) to control light spread and reduce the flare that can result from light striking the camera lens.
Thanks Jamie....
