>This is from a small Milo branch, 4.75" dia. x 3.25" tall. Turned green end grain with thin walls and rounded bottom. Bark areas dried with ripples and the rim has a bit of a wave. Question: The branch was not perfectly round. Should I have turned away the bark inclusion and be content with a smaller diameter piece which would have dried without these 'defects'?
>It looks fine the way it is, nice form, nice coloring, and leaving the bark in gives it some interest.
I don't think there would have been any less movement if it had been turned without the bark because you would have done nothing to change the unsymmetrical grain around the pith that caused the wood to move.
>I agree with Russ, the bark and distortion add interest, it is a very pleasing form. Did you do anything special to the pith to control splitting and checking?
>Glad to finally get to meet 'The Man' in Portland. Russ, you make an interesting point about the asymmetry of the grain around the pith. Most of my Milo pieces have been from dry wood, so I don't have that much experience turning this green. Without the bark, though, I think any movement would be less pronounced and more of a gradual out-of-roundness. The bottom was treated with CA glue, and while this piece had no cracks, it is fairly common around the pith for this wood. The sapwood here is quite light and it was soaked for quite a while in Russ' 'witch's brew'. Over time, I think the sapwood will darken a lot more.
>Nice Bowl David. Are many people allergic to Milo? Years ago I visited Jack Straka on the big island. I got several bowl blanks from him, mostly curly koa but including one of milo. I tried several times to turn the milo and would always start sneezing. I finally gave up and gave it away for someone else to finish.
>in some people. Anecdotal evidence supports a friend's statement that the oldest dry pieces are the greatest offenders. Working on dry Milo causes me to sneeze too, but fortunately not more than once or twice. After that I am good to go. The tactile quality of smooth Milo wood is to many worth the bother and irritation if not too severe.
