finishing recommendaton please
ken chase
>I desire a high gloss finish but without the plastic look of polyurethane and the fumes of lacquer. I like waterlox but not the problemsit brings when the can is less than full. Any suggestions will be appreciated.
Thanks
Ken
Re: finishing recommendaton please
Mark Wollschlager
>Not trying to be flip, but Waterlox is available in a 2 ounce quantity, in a foil pouch.
They have it at the local woodcraft here or it can be mail ordered direct from Waterlox.
Not terribly economical but its enough for a couple of smaller pieces or one larger and its not as painful to throw leftovers away.
Just a thought.
Mark.
Re: I store my Waterlox.....
Jamie Donaldson
>... in a clear plastic squeeze bottle as the supply from the can diminishes - just squeeze out the air to keep the supply from turning to gel. I think the bottle was originally a dishwashing detergent container with a closable spout.
>You can also get Bloxygen. The inert gas mixture "shields" the remaining Waterlox or other finishes in the can from oxidizing. I have known people who also use propane from their small torches for the same purpose.
Just "squirt" a little in the finish can after use.
TDaniel
>I used propane for a while and it helped but it is not as good as the bloxygen. At one time I used a lot of the green can Waterlox so I didn't have to store it for very long but now I use very little and I now have a problem of it getting thick. The red can product takes longer but it is worth trying. Waterlox makes about 4 different finishes and each has some positives and some negatives. I used to mix the red can product with the green can....some times it worked and sometimes it did not. If I had to use only one Waterlox product it would be the red can.
TD
George Van
>Ken, like many others I break my Waterlox into smaller containers. I save the 8oz water bottles, small drink bottles, some are only 6oz, and keep it in them. When I mix a finish I measure a small batch accurately and this is sized for an 8 oz bottle. This works for me.
Terry Quiram, Roanoke Illinois
>I decant Waterlox into small baby food jars.
eliot d
>I have to admit that I haven't tried it, but the best sounding solution I have heard for saving finishes, like Waterlox, from jelling up is to store the stuff in a bottle that takes one of those wine stoppers that come with a pump so that some of the air can be pumped out. You can get them at any wine/beer shop.
I wouldn't be surprised...
david
>if the elements from the Waterlox would eventually dissolve through the detergent container walls. Don't recommend this as a long-term storage vehicle.
Polyethyle terephthalate or PET *LINK*
Mike Brazeau
>I have stored Danish Oil in a clear shampoo bottle, which is PET, for 5 years with no ill effects on the plastic or the mixture. The chart at the link gives an Excellent for Organic solvents and a Poor for Hydrocarbons. Doesn't exactly jive. I use the marble technique in baby food jars currently and am going to try some in a small bottle with dispenser top as it would be much handier and top up with marbles.
Chemical resistance chart
About Waterlox
Gerry Meekins
>I�ve tried marbles in my Waterlox can and found it messy. Now I just transfer it to smaller bottles like a lot of others here do. Just remember, NEVER shake your can of Waterlox.. Unless you want Water-Jello! DAMHIKT
Gerry
