Most excellent! Thin spindles are one of mostest favoritest things to turn and the skew and I are finally becoming friends.
And what a nice idea for illustrating the technique in the link. I liked the animated GIF, but the succession of tool positions above is an especially good example of an effective technical graphic illustration. I usually cut such curves with the long point up - I'll certainly try your method soon.
I hope you don't mind if I bookmark your web site. There's a wealth of info there! (You must have a compulsion to illustrate and teach :) The first one I clicked on at random was about the hairsticks which I also made one year as Christmas presents.
BTW, I strongly agree with the value of chucking the headstock end of a thin spindle as you suggest on your Turning12 page. However, instead of using a chuck with jaws, I've come to prefer turning a quick #2 morse taper on one end (about 1/2-3/4" long) then jam that directly into the headstock. This is pretty quick and seems to work as well as a chuck, but gives me a bit more working room on that end. I do use the 4-jaw chuck for turning larger diameters, such as for tops and weed pots which I turn without the tailstock.
Re: Just Skewing Around & More Skewing Around *LINK*
