Finishing help
Finishing help
Finishing help
Jim Rutten
>I usually finish with a couple of coats of sanding sealer, sanded between coats with one of those sanding pads that looks like it should be used to scour dishes. What do you call those things anyway? Mine is white and sold to me by woodcraft for just this function. But I digress. After I put the sanding sealer on the piece it really looks good, but when I cut it back it is dull looking. So my question is can I sanding sealer, cut back, sanding sealer, cut back, sanding sealer, bealle buff, or must I sanding sealer, cut back, sanding sealer, cut back, sanding sealer, cut back, bealle buff. In other words is there a good reason to cut back the sanding sealer after the last coat?
Re: Finishing help
Is sanding sealer your FINISH?
adrien
Re: Finishing help
No I am going to bealle buff it last
Jim Rutten
Re: Finishing help
Re: Finishing help
david
>Jim:
If what you desire is a gloss or shiny finish, by all means let it go after you Beal buff and wax. Just make sure your base finish is built up enough because the red rouge may erode through the finish, whether it be sanding sealer, varnish, lacquer, etc. If you want a dull or matte finish, then the white buff you are using works well.
Re: Finishing help
Re: No I am going to bealle buff it last
ET
>Sanding sealer is not a finish. It is meant to seal the wood and contains stearates that make it easy to sand smooth before the final finish is applied. The Sanding sealer is not a hard wear resistant finish that will polish up the way that a varnish or lacquer will. I have sanded a sanding sealer and given it a coat of paste wax to improve the shine; but that was on some book cases, and I did not have the time for more coats of varnish. ET
Re: Finishing help
Thanks
Jim Rutten
Re: Finishing help
Re: Sanding sealer = thinned Spackle
Russ Fairfield
>What you are using is essentially Spackle that has been thinned to a brushing consistency with either lacquer or shellac.
Re: Finishing help
Jim Rutten
>Great analogy, Russ!
Re: Finishing help
Jim Rutten
>So ET are you saying I shouldn't sand the sanding sealer after putting it on? I have gone straight to the bealle buffs without using sanding sealer but sometimes have gotten streaks, especially with the white diamond. Haven't had any problems since I put the sanding sealer on first. Please continue this conversation because I am still learning. Thanks.
Re: Finishing help
Re: Finishing help
RonZ
>I don't know what sanding sealer your using or what your application is. I use Mylands cellulose sanding sealer and dillute it 50/50 with nitro thinner after sanding down to 400. This allows it to soak into the wood and build up from here, I usually do two coats and cut back with Lieberon's 0000 steel wool. I use the white [the finest] non woven pad on wood like ash so not to get the metal dust in the pores. Chris Stott finishes with paste wax applied with 0000 steel wool and buff. I usually follow with melamine of friction polish depending on the application. For food use I use either Mylands wood oil or pure tung oil and then no sanding sealer is necessary.
Re: Finishing help
Deft sanding sealer = thinned lacquer
Jim K in Trappe, PA
Re: Finishing help
Ric Taylor
My Experience is Different
Ric Taylor
>I use Mylands celulose sanding sealer, diluted 50% with thinner, sanding between coats with progressively finer sandpaper up through 400 grit. Buffing with the Beale system results in a smooth high-gloss finish.
Ric
