Thanks for all the feedback and more info (long)
Craig Daymon
>I have contacted Doug about 5/16" tools. He's going to call his steel supplier and look into the possibility.
I do put a long bevel on most of my spindle tools, especially the shallow detail gouges. I know with end grain you are suppose to hollow from center out, but I was getting a real clean cut with that long bevel on a 1/4" tool, making shallow cuts from the edge working in. It just got a bit chattery doing this at about 1.5" off the rest. Probably, I think, what would work best for me would be a long bevel going in as long as the cut is moving away from center and then shift to a short bevel working from center toward the transition point. The short bevel one I could probably make from drill blank, but the long bevel I would rather have a shallow detail gouge.
I like Mike's supported tool and for most projects of this size, it would be great. Might even be best for what I am doing, but I also need a relatively thin bottom on this.
Current project description:
I did my first thin stemmed goblet recently. About 5" tall with a 3/16" stem. Then I did the first attempt at the project idea, an egg-shaped hollow form at the top of the spindle and a bowl shaped base with a heavy rim. I'm also considering a hollowed bird head covering the entry hole on the hollow form. I plan to call it, "Leaving the Nest". The first attempt is about 9" tall with a 1-3/4" hollow form and 3/16" stem. The proportions are wrong. The egg needs to be more elongated, the entry hole needs to be smaller (vibration mishap) and the nest is far too small. (Somewhat inspired by Vesery's nest on the back of the recent Fine Woodworking.)
Making a spindle steady would certainly help with the hollowing.
But cutting this thing at the end of a spindle is, I think, also why I can do it better cutting inward rather than scraping toward the outside.
I don't know if this changes any suggestion.
I'll post a pic if I succeed.
-Craig
