Pewter inlay question
Ed Moore
>I was intrigued by the use of pewter to fill cracks as seen in the AAW DVD segment on Cristophe Nancy.
Question: Where does one get pewter for inlay work?
Thanks for any help,
Ed
Ed Moore
Ed
Try this place *LINK*
http://www.iasco-tesco.com/cat55/index.htm
Page 130
Thanks, John. Lan ...
Ed Moore
>Brady emailed me and told me that Christophe Nancey is demonstrating at Klingspor's in Hickory, NC, on Saturday. The question becomes, will the topic be pewter inlay? I'm tempted to take two bowls in need of enhancement due to blemish or crack and have him use them in the demo.
It's either pewter or I must try Stephen Hatcher's mineral inlay.
Ed
Re: Try this place
Pascal Oudet
>Hello,
the pewter Christophe uses is the one used by plumbers or zinc workers. it's 33% tin and 67 % lead. with the mix, there is a transition between the solid and the liquid phases, in which the allow has a pasty texture, so it's easy to push it in the cracks with a spatula. if you use the eutectic allow (63 % tin and 37% lead, which was the solder used in the electronic industry), the transition is sudden from solid to liquid and it will be difficult to control where the alloy will go, it will roll on the wood surface.
Pascal
Pascal, you have identified a serious ...
Ed Moore
>problem. LEAD. I was hoping to use a lead-free pewter, but it sounds as if this may require more skill and probably a hotter flame. And lead-free pewter may not be suitable for filling cracks. Hmmm.
Maybe minerals are the way to go instead.
Thanks, Pascal,
Ed
Re: Pewter inlay question
Brian Hahn in SW Wisconsin
>I'd use some old pewter coasters that I hate. Call it recycling and it will be a hit.
I wouldn't worry about the alloy composition, unless you use the sniff test to determine when it is just hot enough to melt.
Re: Pascal, you have identified a serious ...
Peter Hyde
>Ed,
The link that John supplied has lead free casting pewter and a lot of info
Pewter inlay question - safety??
Ed Moore
>Pascal implicitly raised an important question when he mentioned the alloy of pewter that is used in the process. Apparently for ease of use one should choose 1/3 tin and 2/3 lead - which raises red flags about the safety of using so much lead. It is obviously difficult to control the melted pewter with a spatula and if the 2/3 tin and 1/3 lead is more difficult to use than the high-lead content pewter that Christophe uses, then where does that leave the lead-free pewter? It may work for molds and little else.
Maybe pewter inlay should be for ornamental pieces only and not for anything which might be handled or used for food. ???
Thanks, all.
Ed
Mark Kauder, Phenix City, AL
>ED,
I don't know if they still do, but Highland Hardware used to have this stuff that was like pewter, but melted at a much lower temp - low enough not to scorch the wood. Easy to use. I used in for an inlay in a quilt rack that I did.
I could not find it online, but give them a call and they might be able to help.
Mark
Re: Pewter inlay question - safety??
>Ed,
First off, "real" Pewter contains no lead. Lead alloys tarnish and dull rapidly, whereas the lead free stays brighter longer. When I was casting pieces in Pewter, I always used one of the lead-free alloys which was 93% tin, 2% bismuthe, 3% antimony, and 2% copper. The bizmuthe lowers the melting point, and the copper afforded the ability to do some chemical patinating for color. At one point we made our own alloy that was about 12% copper that would patine almost like bronze but not need the high temp equipment to melt and cast.
What you are describing is what I think used to be called "casting metal" often used by pattern makers. Never used for food-ware.
I have done a piece with pewter cast into the crack as in the oak bowl in the pic. It's fairly simple to make a plaster dam for the inside surface of the bowl and then melt the metal into the crack using a soldering gun. I also used to use it to fill large checks in carvings, expecially in darker woods like walnut and cherry.
Thanks, Mark. I took a ...
Ed Moore
>serious walk through the Highland Hardware catalog after I read your post and saw nothing about fillers of any kind. They do mention pewter spinning, but that's a different game.
I have just about given up on the idea of pewter inlay work. I might use brass filings and epoxy, a la Jimmy Clewes.
Thanks,
Ed
Thanks, Mark. You know a lot more ...
Ed Moore
>about this than I do. I have decided to forget pewter inlay work and try minerals, brass, and other fillers that make CA glue and epoxy feasible.
Thanks,
Ed
Re: When I started reading this...
Allen Neighbors
>post, I was thinking of mixing powder into epoxy for fillers. Then, after reading more of the answers, I realized they were talking of melting it and casting the fillers.
Well.
Would the powder that is on page 130 in the catalog John mentioned in his post be amenable to being mixed with epoxy? Is it fine enough, or is it not a powdered substance?
Just wondering... curiosity got the better of me, I guess. I'm always interested in trying different things for inlay work, but I've never thought of melting anything... just figured it would scorch the wood.
Allen
...just wishing it would quit raining in Childress
Allen, have you ...
Ed Moore
>looked at your AAW DVD? It shows Christophe Nancey melting the pewter and heating the spatula to work the pewter into the crack in the wood. Interesting, but not enough for me to risk lead in the air.
Ed
Re: Pewter Inlay - long
>Ed,
Epoxy with inclusions is easier in some respects, but remember that using mineral has it own hassels due to the hardness of the stone (not the In-lace plastic stuff. The plumber's wiping lead that Pascal described is a pain to use and get a joint solidly filled. Good pewter melts easily with a soldering iron so no flame is volved, and it flows well into small spaces. What you do need to do is prep as much of the crack's faces as you can reach with a small burr so that each face is concave and allows the metal to flow into the wall thickness a bit wider than the crack. Then if the wood shrinks, the inlay won't fall out.
Making the plaster dam is as simple as putting a narrow strip of masking tape over the inside of the crack. Wipe a bit of vasoline over the tape and surrounding surface and cover the area to a margin of 1" with plaster. When the plaster sets, it will slip off from the grease. Remove the tape and put the dam back in place braced against the other side of the bowl to keep the seal. Right the piece with the open crack up and start melting your metal in from one end of the crack. Proceed along keeping the iron in the liquid metal until you get to the end. Best is to over-fill and than cut the metal back as you wish. There will also be a slight bump of metal on the inner surface because of the thickness of the tape you used. You can easily turn this off flush.
Try it!
Re: Not a member of AAW.
Allen Neighbors
>Ed, I'm not a member of AAW, so I don't have the DVD. But I'm curious if you could just mix the powdered pewter into epoxy and use it like that as a filler. I mix brass filings, and turquoise and coffee... why not the pewter?
turtlefeathers for metal dust..
>Allen Go to the turtle feathers link below. You can order metal powder to mix with epoxy, Inlace, CA glue or whatever.
Re: Thanks, Mark. I took a ...
>I looked for it several months ago and aparently they quit carrying the stuff. I think they called it Rose metal. It was really expensive and you only got a very small can.
Cost
>John, a good safe pewter should run you about the same as a good steak; 9-10/lb, but buy it from a smelter in ingot form, remelt and cast it into sticks that are easier to handle.
Re: Pewter inlay question *LINK*
Darrell in Oakville
>I find my pewter at garage sales. A nice Birks plate for $1, and it's lead-free. I just hack off what I need, melt it on a camp stove. I also picked up a few of those pewter beer steins, the ones with the glass bottoms. Where was that article I did? Ah there it is... see link below.
And I also did a solid pewter pen once. The stuff turns easily with sharp tools. The shavings look like Christmas tree tinsel.
Darrell
Wood Hoarder, Blade Sharpener, and Occasional Tool User
pewter rings article
Lan Brady
>Ed,
Just got back from the demo. It was worth the trip. He spent the morning carving bowls and coloring. The afternoon was hollow forms. He inlayed a bowl with pewter. The AAW video just about covered it. By the way, his pewter was 33% tin 67% Lead!!
Lan
Jimiles-Charlotte, NC
>I also was Christope Nancy Demo earlier today ( Sat ) at The North Carolina Woodturners Club in Hickory N C. Christpoe indicated that the pewter he uses as several posts said a mix of tin & lead and he gets it as a plumbing supply. After he melted and placed it with a curved spatula he sanded it smooth. Don't think I'll try that.
Very good demo on sculpture & carving.
Christope is here for about a week at Arromont in Tenn. and doing the Carolona Mountain Woodturners ( I think ) next Sat. in Asheville N C
don lewonczyk
>Ed, if your still interested in a pewter inlay look try Lab Metal. I read it somewhere in one of the wood turning mags. Spread it right out of the can to fill cracks or build up surfaces on all kinds of material including wood. Can be drilled, sanded and even painted or finished with enamel or lacquer. Didn't see anything on my can about oil finish though. They have there own brand of solvents but I think(not for sure) acetone will do the same thing. I'm going to try it one of these days I keep telling myself. DonL
Don, Good idea!! Have you ...
Ed Moore
>ever put any on a piece of wood and sanded it later? I would be very interested in how it finishes up. I hope to cover defects with butterflies, dragonflies, acorns, or whatever, done in pewter or a liquid metal.
Tomorrow I will try to locate some of this product. I see that it is made my Alvin and is available at shops that aren't likely open today.
Thanks,
Ed
