>Seeing Sean's post and knowing I am going to have to build a new shop started me thinking that we can learn a lot from other's who have been down that road. Are there things you wish you could change about your shop, add to it, or wish you had done when you built it?
>I wish I could have put my compressor and dust collector in a seperate room with sound baffling walls so I wouldn't hear them when I use them. The dust collector isn't bad, but I hate to hear the compressor come on. I also would like to have a large window in front of the lathe for natural light.
>My shop is about 14 x 28 and not near big enough. It is attached to the garage, insulated and drywalled. I have plenty of outlets, off the floor, but none at bench heighth. Big mistake. Also, I would have added outlets on the ceiling (planning for this fall). More windows or at least bigger windows.
>What considerations should be taken when locating the lathe by a large window (or any window for that matter)? What's the risk of a piece flying that way...or are these plexi-windows?
>Carole, I built my 20'x40' shop in 1991.One good thing I did when planning my shop was to design it with a wooden floor. I knew if I had concrete, I would have a vehicle in there all the time, taking up room. Plus, I wasn't getting any younger, and I knew concrete flooring was hard on your feet and legs. You can always bolster the floor where you put your lathe... I did.
I also put in one pedestal plug-in in the floor, and wished I had put in three of them. I put them all around the walls, and on the ceiling.
I also put in a 36" diameter louvered exhaust fan in the East Gable, (our wind prevails from the SW), and windows on the West end, to allow air flow in the spring and fall.
I planted Lombardy Poplar trees on the West end to shade it from the afternoon sun.
>My shop is perfect. Just perfect. I have every tool known to man and they are sharp and cut true. Not a spec of rust or debris in there. I sometimes wish I had made it a little smaller The heat and AC bills are a bit higher than I thought they should be and I am tired of having to recharge the golf cart between machines. Last month, termites ate a board out of the trailer while I was driving from the jointer to the planer. Living the dream, NO! Wait, that was a dream.
My shop is actully 14 by 22. I think I would be happy (happier) if it were 28 by 36. With a separate space for lumber storage and a paint room and a room for the DC and Air Compressor.
I would plan the shop layout and pipe the DC under the floor to the TS and Maybe some other tools. If you use a wooden floor that might be easier. Wiring too. Lots of outlets on separate circuits about 42" off the floor.
Are you on Acreage? If I had the room I would let the DC blow the crap out into the woods and never bother with a bag or a filter.
Can't have too much light. The window over the lathe is nice.
>Ditto on the separate sound proofed room for the dust collector and the compressor. In summer vent the compressor out side, but always vent the dust collector inside. 1 micron pleated paper filters make this possible. I also do flat work, and the one thing I most underestimated is how much room I would need for wood storage. Wood for current projects, and stash. It could easily take half of the wood shop.
>It would be better to use polycarbonate plastic window material [i.e. Lexan (tm)] instead of plexiglas, which is acrylic-based and very brittle - it will shatter on impact with most flying objects of any significant mass, leaving sharp shards similar to glass. Eye shields on tools (i.e. grinders, router tables, etc.) should also be made of polycarbonate plastic instead of acrylic plastic.
>Uh, huh. And I guess you think Ruth will read this and jump right in to clean up after you, right? As I recall, she wouldn't even set foot in your shop because it gave her the willies! LOL
You realize another advantage to wood vs concrete when you drop that skew chisel.
I've thought about the whole shop thing a lot while designing the shop I hope to start on this fall. My final plans provide for a 24x40 side with high bay door and concrete floor for "dirty" things like maintainence, welding, metalworking. The woodshop side is 20x40, wood floor with a basement below for compressor, dust collector, storage, and root cellar. The shop above will have a small front room for office (with computer) and woodturning with a windowed north wall, and a large room behind for flatwork. (I think dividing the space will make it easier to heat just the woodturning area.) Sissor roof trusses for extra ceiling height.
Some points important to me:
- at least one WIDE double or rollup door for machines, projects, stock.
- shop floor at ground level (no steps)
- good lighting, natural + electric.
- tall ceilings (if you work with boards)
- more outlets than possible to use
- Heat + AC
- running water, phone, ethernet, intercom to house
- space for wood storage
- removable plywood wall covering
- convenient main shop electrical cutoff switch, but with some unswitched outlets for battery chargers, radio, computer, etc.
- smoke alarms audible for 1/4 mile
- French doors opening on deck overlooking woods and back pasture!
(doors aligned with radial arm saw for extra long stock)
Security: we don't live an area where theft is likely, but I will still secure the windows/doors and install an alarm system. I also am checking into a sprinkler system for fire protection.
During planning it is helpful to make a scale layout to assure logical equipment placement and enough working space for each power tool.
Before I built my shop the best advice I received was to build as big of a shop as I could afford. Even if I had to sacrifice some interior finish at first. (you can always add that later). The idea is that building shops tends to be a one time opportunity and it is very difficult sometimes to gain more space later. It is always the most affordable time to build space as well. Adding space later is never as affordable.
>Thad, I mounted a section of plexi-type glass salvaged from a storm door inside the window (bottom half only) where my lathe is. Mounted it so that it could be removed fairly easily for cleaning. It already has a spattering of CA glue that spun off a piece. Nothing big has come off the lathe and hit the plexi-glass . . . yet.
>What a great question Carole. I am moving into a new shop 18x32 and all of these answers to your post are helpful. Good luck on getting your new shop and thanks again.
>Put a lot of outlets at a 48" height. Much easier to plug things in and you can lean things against the wall and still get to the outlets.
I also ran a sub-panel which allowed me to run several circuits. Almost every outlet is on it's own. This allows you to change any location to 220 if you purchase new or upgrade your machines. I had to convert two locations already. One for the compressor and one for a new, larger, band saw. Just make sure you wire the shop with wire that can handle 220 if you ever need to upgrade an outlet.
Having had a shop on concrete and now one with a wood floor, I would say the wood floor is a must.
